Astrolux HL01 1200Lumen magnetic angle/headlight groupbuy
I tried w/ KeepPower P1835C2 (protected, anode included 38.7 mm, anode excluded 38 mm long), I was able to switch on (playing tighten-loosen with tailcap and head), but too long, so the sealing can be seen, and feels way too bad to tighten more.
I received mine (gun grey 5000k XPL). It looks to be built well and with some minimal testing it appears to function as intended. No missing glass, all AUX LEDs and the main emitter light up. Modes and ramping work.
I will probably change the emitter… I chose this one because the sst20 version I wanted was “sold out” when I went to order. It isn’t bad, but I prefer an emitter that doesn’t have the yellowish corona and also one that has better red rendering. At the very least, I may apply some dcfix to the lens to even it out.
This light is bigger than expected, and has the weight to match. I think “meat tenderizer” is an apt description.
Note the visual similarities:
It probably would work in a pinch, but cleanup would be a nightmare.
I’m not sure if the version of Anduril is the same as my other lights, but it performs the same for the functions that are important to me. It looks like I can pull it apart and reflash it if desired.
The headband color scheme is unoffensive and it appears to be of decent quality.
I haven’t tried the clip or lanyard, but I don’t typically use those anyway.
Thanks for the feedback! Looking forward to receiving mine, but in the meantime glad to hear the feedback/impressions!
EDIT - Tracking on mine @ 17Track.net is stuck at “2020-1-5 Airline Departure” - ugh!
-Garry
Mine arrived today. I haven’t tested because it’s frozen still. Once it warms up I’ll top off the battery.
It does have a lens though…
It’s 75 degrees here, in Texas.
Any info on the shipping issue with battery, other than the one with cant ship anywhere, as it seems strange that’s the issue as I’ve seen other astrolux products ship fine with batteries
The shipping with battery issue has been within the last three months or so, I have bought batteries in flashlights three times before that and had no problem, but when I did astrolux ft03 group by it got rejected into the United States and I had to get a refund
you could probably PM toykeeper, or tag her (if thats possible, idk how)
I tested out mine this morning. I had some work to do in the basement assembling some shelves so I wore the HL01 instead of turning on the lights.
After a while it wasn’t too noticeable even though it’s big (I had an 18650 in it). Mine is the 4k SST20 and it’s probably better suited for outdoors since it has a decent amount of throw. It wouldn’t be the best for really close up work but what I was doing it worked fine. I had it ramped to ~300 lumens for the hour or so I used it. The head wasn’t distinguishable from room temp.
I can confirm Minocc, as I brought home the USB C-C cable and not charging via RAVPower RP-PC059 PD port. USB A-C works via the very same wall charger.
I just got mine today and I like it! Less bulky than I had expected and very well built.
Does anyone know if there is a PDF version of the manual available anywhere? I prefer to keep all of my documentation in electronic form where it’s harder for me to misplace it. :-}
Yes mine is shipping too.
See this thread for Anduril manual links and diagrams. Banggood links this manual for the HL01 which is from the MF01.
-Garry
[quote=garrybunk]
It’s odd that they have a link to the wrong manual on their site, but I guess Anduril is Andruil. :slight_smile:
Thank you!
as long as it's the same version there should not be a difference.
Mine still hasnt moved since 1-10-20 “Airline Departure”
ugh…lol
BG also asked for a photo of my shipping label, fortunately it was still on the top of my trash can. After I sent the photo, they said they were shipping out a replacement. No mention of shipping the one I have back, I assume its not worth their effort.
If it’s worth your effort, I’m sure someone (maybe me) would be willing to buy your defective one for the right price!
I got two e-mails from them, and in the first one they mention the lens only, the second one is about resending, so to be honest I don't know what will I get. They didn't mention to send back the deficient one.
Received mine with XP-L 4000 on the board.
Glass on it’s place. Very nice tint, imho, no greenish. Is anybody know tint bin?
Charger works from USB A - USB C.
Heavy enough, but very handy in 18350 option in hand. Good spot, for concentrating on medium and long distances.
On arrive temp showed 33 degree in real 17, so calibration strongly neccessary. The real lack is that in 7click to change intensity of blue aux leds, we have a blink after first click, and if you shutdown flashlight on high - it would be bloody in darkness.
The real update in software should take this in account and start a flashlight every time in moonlight, at least first nano seconds, to avoid such blinks in many click configurations.
Any info about tint bin and cri in XP-L of this flashlight wanted :slight_smile:
Tint bin on package is 5A
