Ok, so I’m going to buy some thermal paste (maybe like the MX4). I see a lot of area to cover and some looks heavily applied in the pictures. How much do I actually need. Will a 4gram tube be enough? An 8gram tube? And whatever paste I get should not be electrically conductive (even minimally) correct? Please excuse my inexperience in this type of thing.
\Interested in the second batch for 3
Do you mean a technical drawing with full dimensions? Or what kind of measurements?
You will need only a tiny bit of it, approx less then 0.5g per heatsink. With a 4g tube I was able to mount three cpu coolers and four times a MF01 Mini heatsink plate.
Yes, it must be a non-electrically conductive type, but most types of thermal paste are not electrically conductive anyway.
Yes, a technical drowing with its dimension. I would be grateful. Thank you.
Thanks!
I’ve updated the post #1 and postet the currently valid drawing for the production version. Now the project gets kind of “open source” status.
Okey, thank you man of light!!!
If you happen to have an extra, I will take it
Thanks, Steve
2nd batch is full now, but I will continue to collect interests (post #2) for the case somebody jumps off or the supplier will be able to deliver a few more.
Hi
I’m interested for 2 for the 2nd or 3rd batch.
I’m interested in one. Thanks
Mine arrived today. Thanks!
Now to hunt down my thermal paste…
P.S. Make sure you dig the isolation stickers out of the package. I forgot and nearly threw them away.
1 pcs. I am Interested
Thank you very much, man of light, this is a good job!
I'm Interested for 2
Please put me on the list for another 3. There is a deal on banggood for 41€ and I completed the gang. Now I got every color……
Hello. My name is Muk and I am a flashoholic……
I got my light yesterday and my heat sink today. The heat sink works perfect and renders great sustained output. Thanks a lot M O L!
As a side note. I used Arctic Paste and not thermal pads and I could not be happier with the results. Significant improvement!
Interested in 1, thanks
