Yes, I got the same 319AT from MTN. The MCPCB was perfect for the D10 since the plus/minus contact pads were on the same side and I didn’t have to extend a wire.
I kept the stock driver so I’m not sure how hard it would be to replace.
I don’t feel that H03 is worth paying 4 times the price of D10 as long as price has any significance.
4 times?
It depends, but lately it seems even the “old” H03 has gone up in price.
I bought mine for around $ 26 each, on sale or with a coupon code though.
I remembered $40 on a good deal but apparently wrong. $30 on a good deal. $26 is superb.
Ah, maybe it was € 26
Yes, that must have been it.
This is risky to the direction of this thread I know but can I add red to the requirements ?
What about a good cheap headlamp with decent red light ?
I have many headlamps. D10 is best bang for the buck imo.
Convoy H1 is easy to mod. It’s only 18.86 with coupon now.
The link from Rothstein889 takes you to a porn site don’t click it
That might have the reverse affect.
Marked as spam anyway…
Burn ’im.
Hummm this is true
Boruit RJ02. Not really (easily) moddable except for the incredible ease of a TIR swap. Go from 5° spot to 120° flood by just swapping TIRs in about 30sec.
Comes with a 30°, I think, and swapping for a 60° gave me more flood, as to me the 30° was a bit too narrow. 5°/8°/10° are quite common.
Lightbringer, I’d like to try the Boruit you like. I can’t find RJ02. Is this it?
Smarter Shopping, Better Living! Aliexpress.com
Did I read somewhere that the TIR ’s Convoy sells work?
Yes, that’s it.
If I remember correctly, the RJ02 had high parasitic drain so lock it out .
Dam ,I missed that ,don’t know what I would have done if I ended up on a porn site , thanks for saving me
Certainly looks like it. Don’t think I’d trust any come-with cell, though, so go for the one without.
Any 20mm TIR lens fits. I got a whole assortment and they all work fine. I imagine Simon sells 20mm lenses, too, for the S2+, so offhand I’d say yes.
SIGShooter:The link from Rothstein889 takes you to a porn site don’t click it
You’d forever burn in the hellfires of Gehenna.
You’re welcome.
All those cheap USB charging headlamps (a.f.a.i.k.) don’t have current regulation though.
They just have some resistors to limit the current, and they use PWM dimming for the brightness levels.
This means that the brightness of any mode depends on the voltage of the battery (which depends on the charge of the battery).
Even that Eagle Eye not so expensive headlamp works like this.
Do you guys mind showing me which TIR would give 120* flood?
Umm, the one whose description says “120°”?
https://www.amazon.com/dp/B00YGBJ6NQ
90s and 120s can have artifacts like rings around the periphery, so be aware.
