@paetzi, yes, that’s what the pads will be waiting for. Someone will write a how-to, and you will just need to drill a small hole in the case and connect your wires to the solder pads.
1) great.
2) hidden switch for advanced voltages sounds good.
3)
Understandable. About solder pads : ultimately wires can just be soldered where the contacts are soldered in the charger, dedicated solder pads don’t really add anything.
4) 92mm fan sounds great.
Something else, about the UI :
5) Could there be a way to configure several slot at once like on some chargers, for example the zanflare C4 : before 9s have passed since 1st cell inserted, the first button press enable configuration for all cells inserted. (not saying it should be this way, and in this case 9s is actually a bit to short to insert 4 cells)
The solder connection to the battery contactor is dual purpose, it is both an electrical and mechanical connection. If someone were to try soldering a wire to the board at that point, the contact would fall over when the solder became liquid. Maybe that’s no big deal for someone with solder skills and a quality iron, but that’s not everyone.
Interested in two of these.
Dedicated solder pads to anode and cathode battery rail connectors add some value and they are really very easy to set or put, all it takes is a couple spots where the solder mask is removed or unlaid, and maybe positive and negative (+, −) signs. The impact on the charger's cost is absolutely negligible, virtually nothing.
I see the default charging currents' list was modified, plus an additional 2.5 A value was added. Since my list was written with decimals using point/period as separator (learned back in the days of writing computer programs), but the 2.5 A value was added with comma, it looks weird/wrong. I will refrain from judging the new value addition and how it fits in between, but in any case here is the list (whole point 1) fixed with commas (as BlueSwordM did at first):
1. Adjustable charging current: (0,03A – 0,05A – 0,08A – 0,12A – 0,18A – 0,25A – 0,35A – 0,50A – 0,70A – 1,00A – 1,40A – 2,00A – 2,50A – 3,00A).
Interested in 2 please
I’m Interested for two items
I’m interested in one piece. Need a charger that stops at storage voltage.
In for one
One for me please.
I had read:
.5 was best for gentle charging quality 18650
1.0 was for 18650 that you don’t care about as much.
The specs on my protected EVVA 3500 rechargeable 18650 says standard charge rate is 1000mA which is 1.0 amps.
I am not sure if that means the recommended charge rate, or maximum rate. Or what rate is better for a new cell. Couldn’t find anywhere if they are ready to use right out of the charger either.
Any charge rate that doesn’t heat the cell is a gentle charge for li-ion. I haven’t noticed any heating of my Samsung 30Q charging at 1 amp. Do you notice any heating of your EVVA at 1 amp? That’s like 0.28C, so that sounds gentle to me. Do you have a link to what you read?
Hi, below are additions since last update and the BLF INTEREST LIST file linked to in post #1 have been updated too.
The interest list count now stands at 547 chargers.
POST# NAME
1160 zaibas
1161 Funtastic
1162 Pistonsandgears
1163 Jtm94
1164 gds95
1165 daniu
1166 Batiste
1168 confucius
1169 vicastur
1170 Smoothynobutt
1172 luisgcan
1173 j8048188
1182 atobe
1188 TUNE4IT
1189 w4lls
1190 cheesecheeks
1191 NorthernHarrier
1193 CheapThrills
1194 hron61
1201 mgracia85
1208 Bribo
1219 BadWolf
1222 soppa1
1223 Giulius80
1226, 1243 Day_Light
1227 sac02
1231 thefreeman
1232 Quillz
1242 awoody001
1244 Skylight
1245 zeremefico
1246 jojosupir
If anyone is not on the list please notify me. Thanks!
I’m in for two.
PM sent stating interested in one. thanks
Interested in one
I’m in for 1.
In for 2
Hello rost333 , you’re doing a great job, Thank you.
I suggest you check out two posts, I think they asked for two and on the interest list they’re only listed for one.
Post #1227: sac02 , Please add me to the list for two units, please.
Post #1242: awoody001 , Interested in 2 please .
Greetings
