No flickering on my E03H on any mode. I have moonlight set to 20/21 I think.
Thanks for sharing. Also managed to take my e03H apart despite having tried numerous times in the last year or so. Just needed the right tool to remove the retaining ring which was really really tight compared to my e02. My e02 from clearance now has some 219b sw45k. Still can’t decide what to put in the e03 though.
nice!
what was your strategy to reflow without issues from the nearby components?
To remove I just clipped on the board with the led facing up and used a lighter to heat the copper slab and a tweezer ready to take out the led as soon as it’s possible. For reflowing, still used the same heating method but being extra careful not to overheat and/or knock anything out of place. Used the same method with a nitecore HC60 and YLP Panda 3R and so far I haven’t fucked up yet.
Sweet!
seems heating the copper is the secret
thank you
would probably work on a hotplate too…
notice I have not said anything about using hot air from above the LED (…. dont mention it)
I’ll check when I get home. Haven’t played with my engineering mode yet as well so I’ll check on that too.
EDIT: My battery is at 1.2 volts so I don’t know if it’s related to that. Changed the engineering mode to a lower level. IIRC it was at 20/21 though out of the box. I was distracted by how low it could get I lost count. Don’t experience flickering so far.
I wouldn’t do it with a hot plate.
I think it’s better / safer to heat up the copper chunk from the back with a soldering iron (that’s how i did it too).
With a hot plate all the air above the plate will be hot and you could risk desoldering other parts.
Sorry, maybe not the best place for my question.
A new E02 w/ Nichia only works when I hold the button (switch on after 1 sec or so). I checked w/ another batteries, and it's not in lockout, tried on another E02 the lockout doesn't have momentary mode. Sent mail to Manker too, but I think the answer will be after Chinese New Year.
Tried to tear apart, but can't loosen the head from the body (by hand w/ some rubber to increase friction). I there any method to reset (like in Anduril)?
sorry to hear
mine works both ways
from off
a short single click gives the moonlight mode
also from off
holding the button gives last mode memory (low or medium)
Im not aware of any reset feature.
question:
is it possible you cant tell the light is on, from single click, because it goes to such a low mode that you cant see it during the day? (try a single click from off in a dark room… now can you see the LED is on?)
Im not aware of any reset feature. question: is it possible you cant tell the light is on, from single click, because it goes to such a low mode that you cant see it during the day? (try a single click from off in a dark room… now can you see the LED is on?)
Thank you!
No, I can't notice any light after a single click.
Does anybody know if there’s any TIR lens options out there for the eo2?
I can’t notice any light after a single click.
try changing the moonlight mode to another brightness level
(engineering mode)
good idea, let us know if you find out what to order
I got the idea because I also ordered a knockoff nitecore tini and it is fairly close to the same size.
Decided on 219b sw45k on the e02 and 2700K sst20 on the e03h as headlamp and mini lantern with the diffuser. Photos below (~5500K WB)
Moonlight mode
E03 (SST20 2700K) without diffuser and e02 (219B 4500K)
E03 with diffuser and e02
Went through my box of yajiamei optics to try on the e02. The 13mm with stent removed I used for the Panda 3 is the right height but too narrow so cannot place o-rings in between optics and glass lens.
Also tried this 16mm. I removed the stent and sanded down to fit the interior of the bezel and it fit ok. Without the centering ring it fits with the glass lens but beam is not so nice (with doughnut hole). With the centering ring it fits without the lens and the beam is pretty nice and as it shoud be for beaded tir. But I did notice a drop in output so I checked. @ turbo with old eneloops I was getting ~140 lumens with the stock reflector and only ~100 lumens with the optics. So decided to keep the reflector since I also like the 219b + small OP beam for its purpose.
Was it worth the loss in lumen output, also with the centering ring anD no lens is it still technically waterproof,also do you have a beam shot without the lens? Thanks for your insight
For me it was not worth the loss since I wanted a little more throw for my e02 and I like the beam as is. Now if I wanted a nice flood headlamp for closeup work it would definitely be worth the loss but I have my e03 with diffuser for that (which actually looses as much with the diffuser). I think most of the lost light goes out the side of the optics which a white stent could have helped with. Not sure but maybe painting the sides of the optic white might help improve otf output. With regard to waterproofing, I have modded other headlamps (AT wizard, HC30 and others) where I removed lens (because they won’t fit) and put o ring between the optics and bezel and tighten bezel as much as I can. So far they no problems with waterproofing yet even after caving trips. I just had to clean and lube the o-rings after some muddy trips because mud gets to them.
Thank you for the the information and help, I think I will stick with what I have stock, I’m still somewhat of a beginner.
Sorry but this pcb look like amateur project. Solder bulbs and dislocated parts are ugly
depends on how that thing is soldered, the huge thermal mass of the copper piece might be a real problem in conventional reflow ovens
Maybe they need some real nasty air flow to get the proper ramp up and down speed that dislocates the parts
I didn’t see any ‘solder bulbs’, but they sure used enough solder, a bit much on the switch tabs, but that helps hold it in place.
It seems the pads on the PCB are a bit large, so the parts can ‘swim around’ a little in the molten solder during reflow.
Hello, I’m enjoying my e02 I wanted to pop some DC fix in, how can I safely remove the bezel, thanks everyone
Michael
