Thanks, it’s got a big FET so it must use PWM, but I’m not seeing current regulators or a resistor bank for a second channel. I’ll see if I can make sense of the design later. The red glue looks to be hiding components.
Also applied a layer of d-c-fix self-adhesive Milky (aka Sand) film under the original glass cover lens to further smooth the beam, works like a charm.
Well I have no technical means of measuring output but these lenses are not significantly lossy. Of course diffusing a beam sacrifices throw, but that’s where my Epileptical ™ reflector shields come in. Just got new supplies so will be refabbing them with extended tubing; that should circumscribe cutoff and proportionally boost range. Will be updating my DIY thread on mtbr so stay tuned.
Well Jason there’s a white plastic gasket that fits around the emitter and the base of the lens’ shell meshes with that, just have to line them up. Easy-peasy.
Didn’t compare heights side by side; though initially I too was under the impression that the lens was shorter, once installed it came up to the correct height inside the lamp head so that when screwed back on over the silicone O-ring the bezel held it in place perfectly. Can’t tell you how surprised I was!
Yeah Jason I’d have thought the same. But the white plastic gasket has two levels of raised circles so guess it’s made to adapt to either size XHP. And the square base of emitter itself is flat and flush with the star, only its round dome is significantly three dimensional. White plastic shell encapsulating the lens comes to the same height of the reflector minus the latter’s inner ridge that helps seat the silicone O-ring, which simply sits on top of the lens’ shell without that ridge, it all fits perfectly inside the lamp head itself so no worries. (Interestingly the aluminum reflector seems to have the same size hole at its base as the naked lens.) Anyway once dropped in and rotated under pressure until it clicks into place that lens will stay centered. Still needs the cover glass though to hold it down, but that’s just one more opportunity to apply some d-c-fix.
Just as a heads up if you are interested in using 21700 cells in this SP33v3 or another compatible light the highly regarded Molicell 4200mAh P42A is the deal of the day at 18650batterystore dot com.They are being offered at $4.99 ea until Feb 4th
