I was ready to click the “buy” button to get a Nitecore Tiki when the matter of its PWM at low modes came to my attention. I looked at the video on Nitecore’s website and, sure enough, the PWM is obvious. As I read further about PWM, I read that it doesn’t appear the same to the naked eye as on video camera. Is that true? If so, maybe Nitecore’s video isn’t a good measure for actual use.
The reviewer on ZeroAir said the PWM on this light is terrible, but in his review all he shows are charts. When I said in a comment that I don’t know what that means for “real life,” he said to imagine a strobe light. Is it that bad?
About PWM, I also read this on another forum:
“It’s all about frequency. At about 60hz people can maybe detect it. Above that you are starting to switch faster than the rods and cones in your eyes can follow to where it is undetectable above about 100-200hz. If that is the case, there is no way for you to detect that there is any switching going on at all.”
I looked at the specs on the Tiki and didn’t see anything about Hertz. Is there a standard or a typical rating for LED flashlights?
I don’t know about the TIKI in naked eye, but using the RovyVon Aurora A8U that has PWM, I can tell you that in may situations you’ll notice it without a camera.
I don’t know about frequencies and stuff like that, I just know that in some cases, you’ll notice it (near falling water, when you shake the flashlight all of a sudden…) . Not if you’re staring at it while it’s still, but when it implies movement you’ll see it…
I notice PWM when I move a light. If I am walking and the frequency is low, it gives me a sense of peripheral movement that is not there. Drives me nuts!
Thanks for your comments. The lower two modes of the Tiki (1 and 15 lumens) I would likely use only briefly. If the next higher one, 60 lm, had noticeable PWM, that could be a problem.
PWM on a camera is not the same as with a real eye.
Most of the time it is a visible flicker to a camera but cannot be detected by humans.
There are some cases where PWM is low enough that it can be seen with a human eye.
So it depends on a case by case basis.
I have not tried the Tiki
I do trust ZeroAir reviews
PWM is a somewhat complicated, and polarizing, topic.
I suggest you form your own personal opinion from direct experience, if you dont want to liste to ZeroAir.
my advice is, you have been warned
Im very concerned about PWM
but 50% of people are not…
I notice the PWM on modern LED taillight arrays… it looks like the car is strobing and moving erratically
Im very sensitized to PWM, I spent a long time trying to find lights without it
It is true that what shows on camera may or may not be something you see in actual use
its a deep topic, if it interests you, buy a Tiki and let us know your impressions…
People are of course different but 100-200Hz is way too low. I can easily see 1000 Hz PWM out of the corner of my eye when the light moves fast.
Flashlights like the Emisar series with ~15kHz PWM are flicker free for (almost?) everyone so from my personal experience I would say >10 kHz is a must because PWM is distracting and annoying.
Now is there anyone reading this who hasn’t had the slightly spooky experience of seeing something moving out of the corner of your eye, but turning toward it and looking directly at the spot and …. nothing!
Peripheral vision at work —- something vague and colorless is over there! And peripheral vision is just a bit more sensitive to motion, but not to color.
