Great write up Roughly how many amps is it taking to get those lumens? And how fast does it heat up? I liked the old sst-90 but they were big heat generators.
Too cool! = (not temperature) 1.7Mcd... that is rediculous :D
Good stuff! You are testing lots of configurations. Like PP said some current measurement would be nice.
Please
In my Crelant 7G5 the 90.2 pulls 23.2A on a single 18650 (Samsung 25S) KawiBoy has done some testing with his and while the 90.2 can take more amps he says it really only makes 5200 lumens max and will just heat up a lot with more amps, so he recommends the 23-25A range as a maximum.
While the beam profile from the 53mm reflector in the 7G5 is really great, at 352Kcd it falls well short of this 124mm reflector in throw. The Crelant is more fun, this one almost feels like a weapon!
I may not quite be getting that here with longer leads up through the big heat sink (they’re about 2 1/2” long), I only used what appear to be 20ga Teflon coated leads… they could be 18ga but there’s no marking on them at all. I have some 16ga Turnigy with the silicone sleeve that is far more flexible and am thinking about re-doing it with this wire but it’s so fat I’d have to bore the wire holes bigger and enlarge the slot in the MCPCB for the fat wire. May do it, but this afternoon I am going to go out to the lathe and adapt the tail cap I’d originally made as it has some flare to it that will help in holding the light.
LOL Photonica, only if you’ve never been here.
Large pine forests in the East, big time Hill Country in the Southern Central areas, with big canyons and mountains in the West. The grasslands of Northern Central Texas are vast and of course the Valley down in South Texas grows mega crops. We recently drove to New Orleans on I-10 and I remember counting down the mile markers leaving Louisiana, entering Texas on I-10 the mile marker was 888 if I remember correctly (actually 880 miles)… that’s a LOT of I-10 across Texas and the scenery changes a drastically! And thats across the lower portion of the State.
Looks like a missing piece of a Nuclear fusion machine.
At 1.02 miles the beam still looks intense, very impressive! .... meanwhile, I'm still trying to make a clean solder joint.
Got the original tail cap fitted, the rubber boot no longer has a switch under it but it’s pressed snug so it seals fine.
3.8 pounds of badassery.
Doesn't that seem like a marketable light!
I wish the reflector were available, as it is… as far as I know, it’s one of a kind. A prototype that never flew.
If you ever decide to part with it, would be fun to try an auction right here at blf. I bet there could be some serious interest for it.
I have to agree! Isn't that close to an LEP, beam-wise?
I have a Maxtoch LEP and while it does throw outrageously it only makes 300 some-odd lumens. To throw over a mile with close to 5000 lumens is just insane!
And now you're just bragging! LOL! But rightly so!
Better than Giggles?!?!?!?
Looks awesome. How’s the balance in the hand?
When I got it done my back was kicking me so I sat down in a recliner in the den to chill a bit. Pointed it at the lamp across the room and turned it on… the intensity made me laugh like the fool I probably am! Giggles, hahaha, not even close!
Balance point is about middle of the cooling fins in the bare al head, some inch and a quarter in front of the switch. In hand, comfortably balanced, the switch sits under the joint of my thumb… easy and simple one handed operation.
It’s a wet night, almost foggy with a heavy mist swirling in the breeze. I can see the parallel column of light out in the distance to some 150 yds, but a picture doesn’t show it like that… it almost looks like a Comet is being released out of the column of light. Weird, but there it is…
The Great Pyrenees watching over livestock about 500 yds out in the night doesn’t like this, he’s barking his disapproval in my direction.
The weather was just the same here a few nights ago and I did the same thing with about 9 lights, mostly throwy, 4000K, 5000K and one at 6500K. Took 10 second videos for better capture. Misty mesmerizing movies.
I thought about movies for context but bandwidth and all that… living in the country sucks when it comes to internet speeds.
