Thanks for the offer. I used the 4th code. Amazon told me that I had already purchased this light 4 other times ! I like the SP31, V2 and have gifted it a couple of times.
Sofirn - you should consider a bundle: SP31 V2.0, 18350 tube, and an additional magnetic tail cap. Looks like it would make a great pocket light. I’ve got a pair of tubes and tail caps on order from the Sofirnlights website.
I already have both the LT1 and another SP31 v2.0’s but I ordered another 2, one from Sofirn on Amazon and one from another member here. Why? Because it is simple and has an efficient driver. I really wish that it had a shortcut to low, but it’s otherwise the perfect light. I found I was carrying my SP31 V2.0 as much as my vaunted FW3A, and while the FW3A is great for close in work, the LH351D 5000k “dogfart” I replaced the XP-L HI with makes a great compromise between spill and flood, and although there is a little green tint shift in the corona, it’s not really noticeable in daily use while the low CRI of the XP-L HI is noticeable. I also want to stuff an SST-20 2700k 95CRI LED in one of these lights for regular use because I miss incandescent, not to mention it’s easier on the eyes at night.
