d_t_a
(d_t_a)
January 16, 2020, 7:59am
2118
Barkuti:
Question and suggestions (for Simon and/or anyone else).-
What are the actual (modder and tinkerer) differences between the classic 26650 L2 and the 21700 L21A? As far as I know, the L2 fits all 26650s, including the slightly wider, market leading Power Long Battery cells. However, I heard somewhere that the L21A has problems with some 21700 cells, i.e. the tube is too tight. If this is so, I would ask the machine shop to slightly widen the internal diameter of the L21A tubes (to ∅21.8 - 21.9 mm), modifying the drawings in the process, this way the L21A would be more appealing and trouble-free . Tip: Lishen cells are the widest I believe, at ∅21.7 mm with a single wrap, see just below:
Both fit ∅22 mm drivers with a little bit of filing, ∅21.5 - 21.6 mm driver bay. Don’t know how deep is it but I guess very powerful buck or boost drivers can be used. 21700 extension tubes may appeal to someone.
Regarding which batteries fit… my experience:
The Convoy L2 won’t fit the Keeppower protected 6000mAh 26650, as per my test. Some 26650s are also tight (may fit when battery is pushed into the tube, but the battery won’t slide out when turning the tube upside down - so it’s that tight).
The Convoy L21A battery tube seems to suffer the same somewhat tight 21700 (it won’t fit the Sofirn 21700, Liitokala Lii-40A, nor iJoy 3750mAh 21700, as per my testing). Genuine Samsung 21700 and LG 21700 appears to fit.
Simon_Mao
(Simon Mao)
January 17, 2020, 3:47am
2119
Barkuti:
new batch has 22mm inner diameter ,dont worry
Simon_Mao
(Simon Mao)
January 17, 2020, 3:48am
2120
d_t_a:
Barkuti:
6000mAH has unconventional size
Yokiamy
(Yokiamy)
January 17, 2020, 8:36pm
2121
I can confirm that, the new tube diameter is 22mm and now a Shockli cell fits.
Also the tailcap is shorter
Anthon
(Anthon)
January 17, 2020, 10:52pm
2122
What about the S21A? Is there a new batch with more diameter?
Blggg
(Blggg)
January 18, 2020, 2:29am
2123
The S21A from the later batch (at least the one I bought about a month ago) can accommodate the Lishen batteries now.
id30209
(id30209)
January 20, 2020, 5:38pm
2124
Simon, is there a possibility to buy just the pill with mcpcb screws and driver retaining ring for S21A?
Yokiamy
(Yokiamy)
January 20, 2020, 5:52pm
2125
Send him a message on AE after CNY, he will help you.
I've been interested in seeing the SST40 driver with biscotti firmware making it to the Convoy Store for ordering
The Convoy Store on AE has message that it planned to open on or about February 10th,that's tomorrow.
I think the odds are on it getting delayed further,maybe a couple more weeks
It doesn't look good in China yet.
Nooner
(Nooner)
February 17, 2020, 12:20pm
2128
Hi Simon.
Any news on the Biscotti 5 amp (sst40) 17mm driver?
Thank you.
oweban
(oweban)
February 17, 2020, 10:51pm
2129
I don’t remember if it was posted before and it’s difficult to search on my phone - is it possible to get that flat-top adapter for the 4X18A by itself? Would be hugely helpful and far better than me trying to solder little copper things onto batteries.
Hope all is well over there.
FlashPilot
(FlashPilot)
February 17, 2020, 11:16pm
2130
oweban:
+1 on that! Id like to buy a few of those plate adapters as well.
oweban
(oweban)
February 17, 2020, 11:37pm
2131
Would be super helpful for other lights like the BLF Q8
oweban
(oweban)
February 18, 2020, 3:40am
2133
Cheers, was having trouble looking through
I’ll make it work on other lights!
Simon_Mao
(Simon Mao)
February 19, 2020, 7:20am
2134
it’s in stock now ,
if you need it ,you can order the 4mode version ,and note “biscotti” in the remarks
zaxar0580
(zaxar0580)
February 19, 2020, 8:42am
2135
it’s in stock now ,
Great news! I was waiting for this! :+1:
Barkuti
(Barkuti)
February 19, 2020, 8:48am
2136
Just curious. Will copper pills be finally made for aluminum hosts? Simon mentioned a run was to be produced long ago, but looks like the thing got frozen. :???:
There are more than enough enthusiasts around here to guarantee sales of a nice batch of copper pills for alu hosts/flashlights, in my honest opinion.
zaxar0580
(zaxar0580)
February 20, 2020, 2:53pm
2137
it’s in stock now ,
Do you plan to sell 20 mm biscotti drivers?
Simon, your Attiny 13 drivers with biscotti firmware has a common know problem: when change modes rapidly (quickly), this driver spontaneously goes to programmable-mode.
Do you FIXed this problem in your new 6 Ampere biscotti drivers?
P.S. Even TK was spoken about this problem in your Attiny 13 drivers.
You have a funny nickname! Welcome to BLF! And hello to you from Russia!
