interested in limited edition titanium copper
I sent my Copper E07 to the US facility over a month ago after it broke and I have not received any word of anything yet. I have tried emailing Jacky and have not heard back.
Now my Brass E07 is completely dead too.
What is going on with this? Is anyone having such a bad experience as me? Has anyone heard from Jacky recently?
This is completely unacceptable.
Interested
I just heard back from Jacky. I will be sending him a video of the Brass and hopefully he will be checking up on the status of my Copper E07. I will update as this is dealt with.
Interested in ti/cu, possibly two, depending on price.
I’m interested in a Ti/Cu if you are still providing a discount code. Thanks
Time for my first new flashlight since 2004! Have a pair of Elektro Lumen FT-3C’s and they are finally playing out & LEDs have moved so far at this point it was time to upgrade.
Ordered a Cu/Ti with Osram 15W KW CSLPM1.TG 6P & purple LED’s this morning. Have some Samsung 40T 21700’s for power already so it should be fun!
Saved $21.45usd with coupon code FFSALEBLF so I thought I would register & share how it goes.
Knowing the shipping from China would be extended with the coronavirus issues over there; I bought a copper E07 with KPL 5k ’s and red LEDs and an E01 with an Osram from the USA store. (Bought a pair of Samsung 50e to run the E01).
That copper is gorgeous! 9/10 machining. It’s not perfect, but as someone with a lot of welding and some machinest work behind him it’s what I would expect and accept for the price. It’s too heavy for most pocket use, but what a show off! The light output for the size, wow. It does have a copper bezel.
Can’t decide on if I should accelerate the tarnishing of the copper or not.
The single Osram in the E01 is just fantastic. It’s my new pocket light. Looking forward to getting the Ti/Cu when it comes.
Jacky emailed me and let me know the Ti/Cu version just shipped; I didn’t ask foot an update & didn’t expect anything with the troubles China is having at the moment. It was a welcomed update.
In the mean time, I bought 4 aluminum sst-20 versions from the USA store to give to friends and family as gifts. The difference in the all copper abilities to heat soak & the lightness of the aluminum models is large!
Hello.
I have not ever used my Ti/Cu E07. I only played with it a couple of times, in the house. Tonight I thought I would take it out for a walk. I took it out of the box and noticed one of the switch LEDs is dead.
What happens now?
I contacted Jacky from Fireflies by email. Communication is a bit slow but he has offered to cover shipping cost both ways and repair the switch LED!
If that actually happens, this is first class after sales service!
Will keep you posted.
goodluck, now with corona it will probably take a while as mail is very slow worldwide… but good they help u atleast.
That cannot be helped. As long as it gets fixed in the end, I will be happy.
E21a emitters now listed on the website for this model.
4500k versions.
I ordered one yesterday. Fingers crossed it’s done right and looks good!
Wow! Looks like Jacky is coming back.
Let’s wait for some other updates like CC driver or buck-boost.
My concern is the FET frying those emitters. I’d be all in, otherwise. Please share a review or update when you get yours.
Me too. I don’t quite understand the Vf requirements and effects, but 7x e21a emitters in parallel should be ok with a 10a battery like a Samsung 50e right? It’s obviously well below the recommend max current of 2a each.
E21 can be run safely up to 2.3A with good HS.
And they will produce more lumens than 219B...
I have asked around with that same questions, and I’ve gotten different answers. If you divide the 50E MCD of 9.8 by 7 emitters you get 1.4 amps per emitter which is perfectly safe for the E21A. However, I don’t think direct drive (FET) works exactly like that.
Worst case scenario is that you’ll need to avoid FET if upon testing turbo the emitters go blue and appear to be overdriven. Please share your findings with the 50E. I’m in for one if everything checks out!
10A isn’t the max current the 50E is capable of but what the manufacturer is saying to stay at or under for continuous discharge, it can be more than that, case in point if you short circuit it it will likely put out a lot more than 10A, DC internal resistance (DCIR) of the 50E is ~30mΩ, with a perfect short that’s 4.2/0.03 = 140A, likely less though, as DCIR can get higher at very high current, and you can’t do a 0Ω short.
In a direct drive led circuit the current is going to be dependent of voltage between the led Vf and cell, and the resistance of the circuit, : the cell DCIR, contacts resistance, springs, wire, traces, mosfet resistance, and the led current/voltage curve, which doesn’t really behave like a resistor, it would be higher at low current, and lower at higher current, between 2 and 2.5A it sorts of looks like a 40mΩ resistance
so :
50E : 30mΩ
spring : ~8mΩ (I measured the PL42G2 spring at 4mΩ each, likely less when compressed, I assume the E07 uses the same springs)
mosfet : I don’t really know, they can be pretty low, like 2~5mΩ ?
7 E21A at more than 2A : 40/7=6mΩ
others stuff : maybe less than 10mΩ ??
total : 59mΩ
E21A Vf at 2A = 3.09V
full cell at 4.18V
(4.18-3.09)/0.059= 18.5A = 2.64A per led (some more, some less due to Vf differences), and the 50E is overdriven
But that’s napkin maths and some resistances are wild guesses (and please correct if I’m wrong somewhere)
Another way to look at it is that in order to no exceed 10A with a full cell, the circuit resistance would need to be arround 110mΩ.
