2x pro
FW1T, FW3A Brass and FW21 PRO for this guy
ok
What would be differences between brass FW3B and copper FW3C for the following: thermal management, dent resistance, weight?
Fw21 pro
FW21 pro, make it happen
Did you say FW21 PRO in copper? ;0)
Same
For the FW21pro would prefer neutral color temperature anywhere from 4000K to 5700K.
But I would prefer in a classic body Lumintop.
FW21 Pro . i need to start forest fires.
im joking.
maybe a garden fire.
I’ve changed my mind about FW1Titanium...
But i would be interested if FW1TiCu available or just the copper driver/MCPCB shelf as stand alone part.
what kind of optics will the fw21pro be using?
FW21 pro with a color temp below 5000k and tint below the bbl
Show me FW21 pro run time graph next to the Nightwatch NS53a also 10k lumens and 3x xhp50.
I do not trust Lumintop. Too many problems and not good enough customer support.
Any more info on FW21 Pro optics? Diameter? Reflector or lens?
when info is available i post it
Brass should be a tiny bit lighter, a little tougher, and much worse thermally than copper
FW21Pro!
How I would like to have an FW1A Titanium…
I voted for everything except the FW21 Pro. The FW1A Pro was a letdown for me with the chosen emitter
FW 21 should be powered by which cell please? thanks
