Nichia E17A/E21A Skilhunt H04RC Group Buy
Use lower modes and CRI Rnn E21A (lower than CRI70). It will be brighter than stock XML2 and has extra 30 minutes longer run time.
[Clemence]
hi if you could put me down for 1 H04RC.
will message you.
thanks.
Thx! I guess I’m going to stick with my tiaras :zipper_mouth_face:
I just ordered 4K and 5K
Don’t worry about tint with e21a. Pretty much all of the e21a LED’s that Clemence sells are right on the BBL line or even slightly below, for perfect tint. Just pick your favourite CCT. There won’t be any green in these LEDs. The color rendering is also absolutely amazing, and unlike SST20 leds’, they don’t go green when using them at lower power.
As for beamshots, that will always depend on the combination of LED and optic used. If you are looking for more throw, go for the quad e17a, and if you want better efficiency and floodier, go with quad e21a.
Here is an example of a Fenix HL50 I had modded with single e21a LED vs the original XM-L2 LED. You can see the improvement in tint is drastic! No more Green!
I have a Tiara modded e21a, and placed an order for the Skilhunt that will be a nice complement with longer battery life.
Also placed order on Virence H04. I already have a H04F with a single 3500K and I like it despite the quirky diffuser thingy. Same threads as the H03 so S1 shorty tube also works if you can get the right one. Also like the Mode B UI. Add/remove levels as you like. I have mine set to all levels except T2 since its almost the same visually as H1. It’s also easy enough to add/remove levels when necessary.
I can’t see the images in the first post. Is it only me?
You are number 26 on the list Darryl, please specify your CCT and kindly complete the payment.
Thanks,
Clemence
These are SKV89’s Tiara Pros:
5600WB
[Clemence]
So excited you are offering the E21A builds again, Clemence! Thanks for putting this together for us.
I can see them, but the URL is pretty long so I'm not surprised some cannot see them.
I’m interested what 2700+5700 would look like… can’t decide if I wanna go mad scientist or play it safe :person_facepalming:
If you can solder, H04RC is unlike ZL or AT, it’s very mod friendly. You can simply swap the LED modules later.
[Clemence]
Ah, I didn’t think of that. Would I be able to have the spare emitters be shipped with this purchase?
Edit: phrasing
Yes, price is $10 for each additional quadtrix E21A LED module, and $8 for each quadtrix E17A.
[Clemence]
You’re more than welcome. I should’ve worked with Skilhunt before, they’re more flexible than the other company. This mod is driven by popular demand.
[Clemence]
Is the 75$ with shipping included ? the crossed out makes it a bit ambiguous.
Yes $75 includes shipping
[Clemence]
Looks like I missed out on the early bird as well :frowning:
Can someone kindly catch me up on E17A vs E21A? e.g. is there much difference in beam profile / throw, runtimes etc.
