You are number 26 on the list Darryl, please specify your CCT and kindly complete the payment.
Thanks,
Clemence
Thanks,
Clemence
These are SKV89’s Tiara Pros:
5600WB
[Clemence]
So excited you are offering the E21A builds again, Clemence! Thanks for putting this together for us.
I can see them, but the URL is pretty long so I'm not surprised some cannot see them.
I’m interested what 2700+5700 would look like… can’t decide if I wanna go mad scientist or play it safe
If you can solder, H04RC is unlike ZL or AT, it’s very mod friendly. You can simply swap the LED modules later.
[Clemence]
Ah, I didn’t think of that. Would I be able to have the spare emitters be shipped with this purchase?
Edit: phrasing
Yes, price is $10 for each additional quadtrix E21A LED module, and $8 for each quadtrix E17A.
[Clemence]
You’re more than welcome. I should’ve worked with Skilhunt before, they’re more flexible than the other company. This mod is driven by popular demand.
[Clemence]
Is the 75$ with shipping included ? the crossed out makes it a bit ambiguous.
Yes $75 includes shipping
[Clemence]
Looks like I missed out on the early bird as well
Can someone kindly catch me up on E17A vs E21A? e.g. is there much difference in beam profile / throw, runtimes etc.
Roughly:
The E21 has an XP-G / 219C size die, and the E17 has half the mm² surface area die of the E21, so E17 is comparable with XP-E die size.
The E21 can safely handle max. 2 Amperes and the E17 can safely handle max. 1 Ampere.
So a quad of E21 can handle 8 Amperes and a quad of E17 can handle 4 Amperes.
So i think a quad of E17 would be more than enough to handle the power of the H04.
A quad of E17 is also much smaller so it will be less floody (tighter beam) and probably have less ‘donut hole’ effect.
But the donut will be evened out by the optics anyway (i assume)
Probably the E21 quad will have better efficiency because they will have an easy job, below half of their maximum recommended current.
But they cost twice as much as the E17, but the LED boards for both are equally priced and not cheap, so for the total price of this modded Skilhunt, the difference is negligible.
The driver of the light will determine the current and thus the run time, wich will be about the same, but maybe a bit longer for the E21 because it will work on a slightly lower Vf because they run at less than half the max. recommended current.
So in all, it seems the quad E21 is the most attractive option for buying this light.
Well said Jerommel, thank you :+1:
For CW and WW, I suggest to use E21A unless you need throwy confined hotspot. Or if you need pure RGBAL color headlamp.
[Clemence]
I decided to go with E17a. The slight drop in efficiency/output is more than compensated by the much higher intensity in the beam. I think it is easy to get a floody beam using a diffused wide optic, but its harder to get a throwy beam. I think the E17a quad board will give me a better range to chose between throwy and floody. The higher intensity in the beam means I will likely use the headlamp in a lower mode, another reason why I won’t worry about the efficiency difference.
If I had more money, I would probably get one of each
Awesome, exactly what I was looking for, thanks guys. I’ll look into them a bit more before committing.
Quote from another thread:
… the tint shift from low mode to high is very pronounced in E21A (neutral to pinkish)…
Is that how they will behave in this H04 as well? (I’m not sure what power levels were being referenced and how that compares to this H04).
Do we have any sense on what the optical efficiency of these two quad die setups are? Is this something maukka can measure? I’m under the impression that the larger the LES, the more losses there are OTF in these TIRs. If this is true, does the gap between the 17 and 21 close?
clemence wrote: … the tint shift from low mode to high is very pronounced in E21A (neutral to pinkish)…
Yup, just like any normal LED. But 4P setup means 4 times less tint shift
Quadtrix E21A gap = 0,2mm. Total LES = 6,22mm
Quadtrix E17A gap = 0,1mm. Total LES = 4,95mm
I’m sure Maukka will do a thorough test about this
[Clemence]
