Nope. That is dependent on what you use for the resistor. In the one I just put together for my Tool AA Ti, I used a 20,000 Ohm resistor. I haven’t measured actual current draw yet, but it should be roughly 0.08 mA (80 uA) on a full battery. Calculation goes a bit like this:
Battery voltage: 4.2 V
LED forward voltage: 2.6 V
Resistor used: 20,000 Ohm
(4.2 - 2.6) / 20000 = 0.00008 A = 0.08 mA = 80 uA
Battery drain (worst case scenario, current will actual drop as the battery voltage drops):
1000 mAh battery ÷ 24 hours/day ÷ 30 days/month ÷ 0.08 mA = 17 months standby time
It’s bright enough to be mildly visible in a decently lit indoor room. Illumination not visible outside during daylight. Relatively bright in a dark room.
Thats interesting gchart. Very simple, just wish it had voltage adjustment.
Couldn’t you add a small resistor in series to vcc to create a slight v-drop in the 10 to 20 mv range to lower the led voltage cut off points.
I haven’t a clue how you could increase them.
Are these pcb’s shared on Oshpark?
A series resistor can/does create a slight voltage drop, but probably not a enough to make it worthwhile to chase. Honestly, I think it’s just convenient & cheap enough to not worry about the small details. They’re directionally correct and informative.
Oshpark links:
Version 1.0, lacks reverse polarity protection but works fine otherwise (this is what is in my Tool AA)
Version 1.1, adds a small PFET for reverse polarity protection. (waiting these to arrive, should be here in a week or so)
Version 1.2, opened up the center hole a bit for better fitment (not yet tested)
I did notice that while installing v1.0 in my Tool that the center hole is slightly narrower than expected and I had to spend a minute lightly sanding the switch to allow the PCB to slide on it. The dimension I used was the same as with other boards, so perhaps it’s just board-to-board variation. Or perhaps it’s a process difference between the regular service and the After Dark service. If my v1.1 arrive with slightly narrow cutouts, I’ll likely open that hole up and call it v1.2.
Sounds good. FYI, I just went ahead and made a v1.2 with a slightly larger center hole. That way if anybody cares to order some, that’s already taken care of just in case.
HM1160 - I’ve only found it on AliExpress, can sometimes also find it by it’s chip label “60AA”
PFET, size SC-70 / SOT-323 (such as BSS209PWH6327XTSA1)
1uF 0603 or 0805 capacitor
A resistor of your choice (I generally use 10k - 30k Ohm) in 0603 or 0805 (for setting the brightness)
4x LEDs of your choice, 0805
Don’t forget a bleeder for your driver, something around 680-840 Ohm
Oh yeah… If this is going in something bigger than a Tool (a Convoy S2 / C8 perhaps), you could use this single sided board to make things easier. It’s squared off because I’m cheap (the square inches you pay are based on the smallest rectangle that can fit around your design). I have dinner of these on hand but haven’t assembled them yet. I expect them to work fine as they’re electrically the same, i just have had a moment to put one together.
I’ve been curious about the exact cutoff voltages. And sometimes I noticed a slight difference using my power supply vs a battery. So I managed to dig up an extended datasheet in Chinese, which I ran through Google Translate. From it, I was able to pull the official cutoff specifications. They are as follows:
Volt Range
VD1
VD2
VD3
VD4
3.87-4.2
Bright
Bright
Bright
Bright
3.7-3.87
Bright
Bright
Bright
Extinguish
3.55-3.7
Bright
Bright
Extinguish
Extinguish
3.4-3.55
Bright
Extinguish
Extinguish
Extinguish
3.4 or less
Extinguish
Extinguish
Extinguish
Extinguish
So… the “official” cutoff levels are: 3.87v, 3.70v, 3.55v, and 3.40v. You might be thinking, as I did, “hey, 3.40v seems really high to be the lowest cutoff! I’ve been taught that lithium-ion batteries are good down 2.8v.” And that’s not wrong. But it’s too easy to think of remaining capacity as being linear with cell voltage. But that’s not the case. HKJ has a great write up about this. Here’s an image from that article:
I used his battery comparison tables and came up with similar figures for some of my most used batteries:
table(table#posts).
||Shockli 1000mAh 14500|Samsung 35E|Samsung 30Q|Average|
|3.87 v|76|68|69|71|
|3.70 v|58|48|45|50|
|3.55 v|24|29|35|29|
|3.40 v|6|16|21|14|
Armed with this knowledge, you could say about the HM1160:
4 LEDs on: 100% - 71% remaining
3 LEDs on: 71% - 50% remaining
2 LEDs on: 50% - 29% remaining
1 LED on: 29% - 14% remaining
No LEDs on: under 14% remaining
Doesn’t sound so bad now, huh?
Circling back around… some of these cutoff values are different from what I initially proposed using my basic variable voltage source. I think the difference lies in that the HM1160 behaves slightly differently when a consistently-connected source is dropping in voltage vs when a source is first applied. That is, when crossing the 3.40v threshold from above by ramping the voltage supply down, the last LED wouldn’t extinguish until around 3.2 - 3.3v. But if I disconnected the tailcap, set the supply to just under 3.4v and reconnected the tailcap, the LEDs wouldn’t light up. I imagine there must be a bit of a buffer zone to keep LEDs for flopping back and forth when the measured voltage is right around a cutoff.
Wow nice finding gchart! Thank you for providing this info. I think I’m gonna stick with v1.0 first, it’s difficult to find the PFET here…
Regarding to the small opening for switch, can I enlarge the center hole on the board or should I sanding the switch?
I ordered two batches of v1.0 and one was too tight and one for just fine. Manufacturing tolerances I guess. I was able to carefully drill the boards out just fine. 7mm I think, you’d want to measure.
Nice practical reference charts on practical battery capacity - I guess gChart stand for “Great Charts”.
I was a big fan of how your HM1160 tailcap performed on the video. But it’s understandable, there’s a difference in how the circuit behaves using a stepped down DC power supply versus actual batteries. I guess the ideal chip was too good to be true
Personally I think the 3&4 LED cut-offs ranges are fine but the 1&2 cut-off ranges are a little too early. The earlier video showing cut-off/extinguishing of all 4- LEDs at 2.9-3V was ideal because it simulates Protected Battery cut-offs. Cutting-off at 3.4V even if there’s only 6-21% remaining is a little early (1 LED was ideal.)
Just a thought - would it be possible to slap a capacitor into the circuit somewhere to help get the LED excited enough to light up on battery power, thus getting closer to it’s performance as on the video using a DC PS?
The observed performance difference on the power supply was actually caused by the difference in rising edge detect (flashlight turning off, tailcap turning on) versus falling edge detection (tailcap on, battery running down). The spec’ed cutoffs for rising and falling can be seen at the end of this translated datasheet.
Unfortunately a capacitor cannot change the system voltage, it will only mimic the battery voltage. And there’s already a capacitor in place.
In short, the HM1160 is unfortunately a “take it or leave it” scenario. It’s handy, but not flexible. For flexibility, you’d need something like one of my smart tailcaps which is running an MCU and can be programmed with any voltage cutoffs as desired. Or… I’m currently finalizing a tailcap that is similar to LoneOcean’s tailcap (in concept and functionality, not design). It’ll use 4 red/blue bi-color LEDs and a couple low-power voltage reset monitors to switch from blue to red to off at whichever cutoffs are desired (in 0.1v increments). I hope to have it ready in the next few weeks.
Yes, as long as you’re comfortable installing the tailcap and ensuring that your driver has an appropriate bleeder resistor. And with the understanding that the HM1160 provides preset cutoff voltages and those cannot be changed. I ask $3 per assembled board. Domestic shipping for $1. International depends… I’m legally required to use package shipping which is usually $13, but I have snuck these through in standard envelopes (at your own risk) for like $2.
Practically all IC’s like to have capacitors around them to help smooth out any small voltage fluctuations. You could probably get by without, but they’re so cheap, you might as well follow the manufacturer’s recommendations (as is done in this circuit, which is taken right from the datasheet).
