180lm with 10440???
What the...
Yea I thought it was too low too so I recharged the battery and tested it with another vapcell 10440 but same result.
could the vapcell be a bad battery? do u have another light that runs with that battery to rule out?
What mode is it programmed to? One of the modes maxes out at 50%
good point that would explain 180 lumens… so double u have 360 then if thats the case…
guess I’m too late for using the code, just tried it and doesn’t work.
It just came into my possession. That was fast!
Question: Why isn’t this LED no longer in production? Or is it? And why isn’t or wasn’t it used more often? The color is a dream, even more than the Yuji 3200K among 5mm LEDs.
I like this light very much, even if it’s not as bright as expected. Surely nowhere near 300 lm.
ReyLight can we get some clarification on the so called 300 lumens when using 10440 when users claim its no way near that?
I wouldn’t expect a response for a while since it’s a holiday in China for several more days. Really only one sample has been measured which could just be a dud.
Second post is 3rd above...
Coaster: mortuus:ReyLight can we get some clarification on the so called 300 lumens when using 10440 when users claim its no way near that?
Second post is 3rd above…
I used the word measured on purpose.
Visual estimation of lumen output is about as accurate as “seat of the pants” horsepower. IMHO
I’m not saying it doesn’t appear dimmer to the user who said so, just that it is not a measurement and human vision is tricky.
There very well could be a design issue also. I’m just saying it a bit early to jump to conclusions.
Coaster is right, my estimation might be wrong. I can only compare with lights that have a different beam and color, unfortunately. There’s not so much difference between 180 and 300 lm that everyone would see it immediately without direct comparison. And maybe I am influenced by the reported measurement.
Quick measurement in bathroom:
D4V2 SST-20@3000K, 100 lm equal 6 lx
Olight S1R II 1000 lm equal 69 lx
Pineapple maximum = 10 lx, equals between 145 and 167 lm with the above standards.
all measurements done with Benetech GM1020.
Edit: I still might be completely wrong!
I kept it default, so whatever mode it came from the factory as.
Got mine as well today, nice surprise for it to arrive so quickly. Thanks Reylight!
treellama:What mode is it programmed to? One of the modes maxes out at 50%
Try changing modes. Lexel’s Bistro drivers i’ve got had to be programmed otherwise they deliver only 50%.
not reprogrammed but correct group should be chosen from options menu
I lost the manual so don’t know how to change modes. I wish Rey would post the manual on his website.
Eight half-clicks, light blinks once, then flickers. Now do one half-click and you’re in first mode group.
Reverse clicky switch. Full click to turn on or off, half click (tap) to cycle modes.
Program: When the light is on, quickly half click 8+ times.
- Select different modes groups. (1-4 groups)
- Turn on or off memory function. (Default is off)
- Turn off or on moonlight mode. (Default is on)
- Mode order. L-M-H → H-M-L (ascending or descending)
- Reset.
Shortcuts: Quick double clicks = turbo
Modes groups #1-4. - moon-2-20-100%
- moon-10-40-100%
- moon-2-10-50%
- moon-50-100%-strobe-SOS
this light sure has tricky modes… way too many imo, why ? aaa light should be easy to use not so many different modes etc…
