Overall I wonder if this is a fair option for a high CRI thrower.
It is not a throw LED…but no CRI90+ LED that is well tested by BLFers is a throw one.
How does it compare with SST-20? Die is larger. Output is slightly lower. But it has no dome which should make the throw comparable. But which one would throw better? Probably SST-20. But how much? I don’t know. This one has the advantage of widely loved tint.
I’d love to be able to quantify the tradeoffs. I lack the data to do this….
Frankenquads…will have a donut hole. And fighting the hole will make them floodier than a single LED. So they are not for people desiring throwers…
I have a single E21A LED in a Fenix HL50 headlamp modded by Clemence.
Obviously not a thrower by today’s standards, but a significantly tighter beam than your typical headlamp.
What I like about it having the tighter beam on a smaller AA light is that I don’t have to use a very high setting to get the light where I need it, and I can use it around others without blinding them.
I would imagine that if you want a thrower out of a quad e21a, you would need to use a very large reflector or TIR.
TA, I need clarification.
At some point you calibrated your setup with Maukka lights. Results from after and before this point are not directly comparable.
But I wonder about 2 tests which I think are both earlier than the calibration. XM-L2 and 4xE21A.
Can we directly compare the lumen outputs in these tests?
I have not posted any LED tests from after the maukka calibration (mostly due to the issues you speak of). So while the numbers themselves are not that accurate they are all comparable.
I have thought about how to go about posting more tests but there have not been a lot of need for more LED tests recently so I have not bothered.
I don’t agree there’s no need for LED tests. Just today I’ve been thinking that maybe I could offer a bounty to have one of the interesting emitters tested (Oslon Pure). Though I failed to come up with something that would be affordable enough for me yet valuable enough for someone capable of doing so.
True, there might be some LED’s coming out that could use testing. I have not had time to keep up with the latest LED’s. Last “mainstream interesting” LED’s I saw were the Boost HX and SBT90.2.
I can obviously still take measurements, just not sure how to handle the new calibration without making things really confusing.
I understand. I keep my old calibration while knowing it is high, because it keeps my tests comparable over the years. Because it is not too much different from reality (luckily just 7-11% high), sticking to the djozz-lumen does not give a grossly wrong idea of the led performance.
Yeah, if mine was only 10% high then I would dot he same but at closer to 30% that is just too much of a difference to keep the same calibration for me.
I considered changing all my old readings by 30% and updating the old threads but that is a LOT of work and still not totally comparable.
Hey Agro, you like numbers, how about McGivering some stuff together and start doing emitter tests?? Me I am certainly not motivated enough to test every new emitter that comes out, and it sounds like TA feels about the same about it. And koef3 posted some tests for a couple of months but stopped after that. I think BLF is big enough for an extra led tester.
Tiss an option, it is really not that hard, just time consuming. A bench power supply, lumen tube / sphere, PC heatsink (stock CPU heatsinks work fine for most things) with some holes drilled and tapped to fix the MCPCB and an excell spreadsheet is basically all you need to take the measurements.
Then just some testing to figure out the best testing methods, figuring out the voltage drop in the wires etc.
I’ve been thinking about it. But I really lack all the essential items except for wires and DMM. No sphere, no PSU, no cooling setup.
I intend to buy the first and the second eventually but not this year. This year my focus is to upgrade my main EDC light and it will cost me a lot.
Close to 30% is a big error
I do believe that all these tests deserve a warning label telling the readers to apply a certain correction factor, like djozz tests do.
You could add a joke that everything is bigger in Texas.
I wouldn’t suggest calling these Texas Lumens and using them in future tests though, the name “lumen” would be confusing. You could call them something rlse, f.e. likeable measurements and keep them.
Or I would suggest abandoning them. That’s what I would do, serms that in a long term it would be more usrful.
Yeah, that is basically what I have one at this point, If I do any more tests they would be with the new calibration.
I was not aware of the issues with the accuracy until long after most of these tests were posted. Only found out about it due to the muakka calibration lights.
Just wondering if a quad E21A (in series) on a 16mm board could be run in a convoy s2+? I’m not after high output. In fact the dimmer the better. I don’t know the maths though.
If in series, you would need a 12v boost driver. I’m pretty sure majority of S2+ come with a 3V driver. In short, it’s possible with the correct driver
