Sorry, that’s too careless
Thank you very much for your reminder
I contact sales customer service to change the picture
I just received 4 pcs of these, i just put them in my Lii-500 on NOR test.
I’ll report back.
Thx! ^^^
1st run on Lii-500 NOR test (4.2 - 2.8 Volts)
[1] 711 mAh
[2] 721 mAh
[3] 750 mAh
[4] 742 mAh
Doing second run now.
Okay, 2nd run finished.
I swapped the cells in the charger, so that [1] was now in slot 4, [2] in slot 3, [3] in 2 and [4] in 1.
[1] 732 mAh
[2] 747 mAh
[3] 737 mAh
[4] 734 mAh
So it seems there is some difference between the slots of the charger.
Average of 1st run: 731 mAh
Average of 2nd run: 737.5 mAh
It’s ridiculously late here, so i put them in for a 3rd run, i’ll see the results tomorrow.
I put some nickel plated neodymium magnets on the minuses to increase the force of the clamping of the slots.
I must sleep now.
See you tomorrow.
Oh, i forgot about this… ^
The last NOR run was a little better, but not a lot.
I wrote down the results, but i can’t find it anymore…
Anyway, AliExpress page of the new INR14500 shows the graph but it now says “HKJ test” above it.
Hmmm….
hm so not really close the stated 1000mah then? should be marked 800mah then imo.
Mooch said he'll run some tests on 14500 10A :))
Would these work in the GT Micro or is 10amps to much for it? I am using the gold 14500 vapcells and they seem much better then my Efest 700mah in my GT Micro.
Mooch said he’ll run some tests on 14500 10A :laughing:
That is great :+1:
Thanks ,H10 14500 10A have much power than gold 14500
Correction: “H10 14500 10A has much more power than gold 14500”.
I just want to make sure its not to much power for the GT Micro, I would hate to smoke the emitter
vapcell Dennis:…
Thanks ,H10 14500 10A have much power than gold 14500Correction: “H10 14500 10A has much more power than gold 14500”.
Thanks for correcting. my English is very poor :person_facepalming:
If these H10 graphs are correct does that mean we could get around 2500 lumens with an XHP50.2 in an SP10S/Tool AA?
I like the train of your thoughts )))
With this new Vapcell H10 cell, we really need to see some new 14500 lights that can take advantage of it.
I’m rebuilding my previously ruined Tool AA for it atm: FET driver and LH351D. But I could not resist a sliced 3500K 90CRI one because of the tint. I’m halfway the build but it looks like I’m going over 1000 lumens of 93CRI below BBL. (and very hot fingers).
My purple Efests are getting old I guess…
I indirectly inquired Mooch about this very recently here aand, wellp, unless Vapcell or someone else sends him a couple samples, seems that ain't happening in a near future.
id30209:Mooch said he'll run some tests on 14500 10A :))
He bought them over a month ago...
