FW3A mod thread. Post yours!
I got mine from Barry (Sofirn). They should be the same ones used in the SP36 Anduril and SP10S. I’ve checked a few now and the majority of them can’t handle many amps. Convoy S2+ (8x7135) for example turns blue on the highest mode. I’ve checked and rechecked the reflows. Ended up reflowing XPL-HIs and Nichia 219Cs and not had any problems. So all signs point towards suspect emitters atm.
I haven’t kept up so forgive me if this has been done already.
The button was just too sensitive for me so I traded mine shortly after receiving, was recently gifted another and wanted to make it work for me.
I removed the nipple from the center of the rubber disc and replaced it with an o-ring with an I.D. slightly bigger than the O.D. of the nipple.
This isn’t a flashlight-style o-ring but one you’d get out of one of those kits you can buy at harbor freight.
The action is just stiff enough that I don’t turn it on when putting it back in my pocket.
O-ring seems to stay in place from friction so far. It fits into the dished area around the nipple mounting point.
Instead of the nipple pushing in the very center of the membrane switch, the o-ring pushes further out on the dome.
Works great for now, will update post if there are any issues.
/\ Cool — glad to hear you were able to work out the o-ring DIY with success, bansuri!
I’m still using mine with 5/32 and it works great. Must keep tailcap very tight, though. If it loosens just a little, light will cut off above certain brightness level. This looseness can happen if you lockout, which I still do when I’m not using the light for a while. It’s habit. But I’m guessing it won’t do anything regarding parasitic drain… and in any case, drain is probably so very slight, pretty much inconsequential. I know… OCD! :zipper_mouth_face:
Why is that? Is the bezel used as the heat-sink for the LEDs? I thought the heat-sink would be attached to the head, below the bezel. Or is it just extra metal that is needed to suck up some additional heat that the rest of the body can’t do?
I think that recommendation is based on the fact that fw3a doesn’t have the mcpcb screwed down and relies on the clamping force from the optic and bezel for reliable thermal interface.
Ah, okay, that makes sense. Thanks.
What’s the inner diameter on those Armytek rings? Is enlarging the diameter the mod that’s needed?
I don’t have the exact measurements, but if I remember correctly, the ID was 0.9mm smaller that the largest part of the body tube. Took about 10 minutes carefully grinding the ring to get it sized perfectly.I used a Dremel with a sanding drum
Anyone put Nichia 219B into it? Not too much current on turbo?
Mike
219Bs need a low drain cell which drops a lot of voltage when FET switching
That’s not good. I have to rethink that.
Mike
There’s also a 219B specific firmware that can be flashed for more protection.
I have sw35’s in one of mine, using the 219B firmware and a GA battery. I generally just avoid turbo to be cautious, though. Max regulated is enough for my uses.
Thats just reducing the average current, not the peak current
So you deal only with heat not things like Auger recombination
I’ve wondered about that. It’s one reason I stay out of FET with my 219B’s.
Little update on this awesome light using 1 SMD 0805 red led and 1 SMD 12K resistor.
/\ VERY cool, Ryley! :+1:
I did a 219b swap. I flashed a modified version of Anduril that was limited to 60% FET max (219 version in FSM is 75% iirc) and use an NCR18650GA as well as keeping the thermal ceiling around 50-55C. It’ll happily sit in turbo until it throttles without any issues. Didn’t try it with a high-drain cell, I imagine I’d need to be a little more careful with something like a 30Q or higher.
Ignorant here, I have replaced the 219C emitters on my FW3A with 219B ones, no other changes made and I am using a. LG HG2 cell.
Can someone please sum up the issues my setup has and how to fix them?
The 219B config in FSM is 50% FET. I haven’t seen any trouble turboing mine but I’ve never done it for long—and I don’t know if the LEDs get damaged before they start to turn blue.
From where could I download it?
Turbo can’t be disabled via firmware mod?
Mike
