MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8370 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 9 hours 22 sec ago
I jumped the gun on something I thought was about to happen, not taking into account delays obtaining merchandise before listing it. Wink
My excitement got the better of me… it’ll happen, can’t show pics, but it’ll happen. Silly
I have been a mule many years in my life (carrying building materials for a couple of decades), and everyone knows how much I talk, so no offense taken Lightbringer. lol
contactcr
Last seen: 12 hours 36 min ago
NEW PRODUCTS:
20 and 22mm boost drivers
And some new e-switches (YAWN)
And the boost drivers will support 2S and more current in a future batch (MORE WAITING UHUHEUHEUHRRRRRGGGG)
ggf31416
Last seen: 1 week 1 day ago
The 90 CRI LH351D available at MTN is claimed as P6 Flux Bin, Samsung calculator estimates about 18% less output (S2 vs. P2) compared to S6 bin that was tested here. The estimation for the higher Q2 bin is 237lm at 700ma and 760lm at 3A, not exactly promising. How does the output of the MTN’s LH351D compares against the Nichia 219C D240 at about 3A in real life?
I know I can get bare leds with a higher bin in places like Arrow, but I rather avoid reflowing as I would likely need to import soldering paste or find an usable product locally and I would likely mess up things anyway.
Edit: I rechecked the LH351D specs and bins ending in 6 are loose bins,P6 is not some halfway bin between P2 and Q2, P6 means a group of P2, Q2 and R2 bin leds with flux between 320lm-380lm at 1050mA. Also the highest bin at 4000K 90CRI is Q6 (Q2, R2 and S2), so P6 is only a bin lower than the maximum at that color temperature and 90CRI. In fact you may get a R2 from a P6 and only a Q2 from the Q6 if you are lucky/unlucky. I guess the LH351D is just more efficient at 5000K where you can get the S6 bin than at 4000K.
DB Custom
DB Custom's picture
I’ve been testing the 20mm Boost and it’s really nice, robust enough that it just doesn’t give a lick of problem no matter what I do with it. I currently have two of them, one in an L2 with XHP-35 and another in an C8+ with XHP-35… single cell operation and a very wide range of control. Both of these lights are special lights, the L2 is a clear machined finish and the C8+ is a prototype that I got lucky enough to end up with… and now both have outstanding drivers that really deliver! My C8+ is getting 1999-2003 lumens in my newly rebuilt calibrated light box. It manages heat exceedingly well, ramping up and down to find a sweet compromise on it’s own accord, and yet if I want to keep bumping it to Turbo it will take the heat more than I can. Just gotta love it!
Tom E
Tom E's picture
Last seen: 7 hours 41 min ago
Dale - are the boost drivers you using set to 2.3 amps out? I see that's a config option and sounds perfect for a XHP 35 HI, specially with those lumen #'s you are getting. Could be 2.0 amps as well...
DB Custom
DB Custom's picture
Yes, 2.3A out. The UI is Guppydrv3.0, quite a lot of options.
It can work with one or 2 cells, is more efficient and cooler running with 2 cells as it isn’t boosting as hard. I’m really enjoying the C8+ a lot, the L2 as well but use the C8+ more it seems. (size factor I’m sure)
I have the C8+ set for 5 levels, with a short 20ga loop between the MCPCB and driver lead at the emitter I see…
0.02A
0.03A
0.32A
0.65A
2.22A
This from a Sony VTC5A at 4.09V.
Tom E
Tom E's picture
He doesn't say but looks like an ATMEL MCU based on firmware offerings? Good it's planned on to offer e-switch support.
contactcr
The listing says 1S battery config only for the first batch. Is yours a prototype?
DB Custom
DB Custom's picture
ATTiny25, yes.
And because someone will surely notice, yes, I machined the driver bay in my Prototype C8+ to accept a 20mm driver from Richard. Wink
THE_dAY
Last seen: 2 days 10 hours ago
^DB Custom, I hope you are doing good my friend. Smile
I want to give my thanks to Richard at MtnElectronics for installing a Nichia R9080 onto a custom board for the Relio light.
He has helped make an awesome light even awesomer!
Skylight
Skylight's picture
Last seen: 1 hour 17 min ago
I managed to resolve the flickering problem on my XHP70 zoom flashlight mentioned earlier. Party
I just removed a 26mm MTN driver from another flashlight and swapped the MCUs. The light shines nice and steadily now. Some weird behavior is left, though, as with Crescendo at turn on it stays at a low mode first and after two or three seconds ramps up very fast to maximum brightness. Flat Stare The ramping on the other driver worked much more smoothly. But I’m happy with a non-flickering flashlight and don’t mind as much about a not linear ramping.
MascaratumB
MascaratumB's picture
Last seen: 2 hours 34 min ago
I guess it has been stated before that Richard was hands full with different projects. But…looking currently at the driver’s section of MTN, many (almost all!) FET DD drivers (and not only these) are out-of-stock.
Does anyone know if or when they will be restocked?
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
contactcr
and boost, buck, mtn triple xp
Scallywag
Scallywag's picture
Last seen: 8 hours 5 min ago
Yes, nearly all of his popular drivers are out of stock.
I suspect it is due to the confluence of the orders mentioned, as well as the summer break, and IIRC a recent baby as well.
I hope he restocks soon, as many of these drivers are virtually impossible to source elsewhere. Richard is an invaluable community resource. However, I do not wish to pressure him in any way to speed things up, because I understand how life goes. I just set some e-mail “back-in-stock” notifiers and continue on – the lights I’m working on/planning currently are for Christmas gifts anyway Wink
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
e1000
Last seen: 11 hours 57 sec ago
Scallywag wrote:
Yes, nearly all of his popular drivers are out of stock. I suspect it is due to the confluence of the orders mentioned, as well as the summer break, and IIRC a recent baby as well. I hope he restocks soon, as many of these drivers are virtually impossible to source elsewhere. Richard is an invaluable community resource. However, I do not wish to pressure him in any way to speed things up, because I understand how life goes. I just set some e-mail “back-in-stock” notifiers and continue on – the lights I’m working on/planning currently are for Christmas gifts anyway Wink
Well said sir, well said.
MascaratumB
I concur! No need to rush, just was wondering about the “sold-out” in some many pieces!
Maybe he’s working on a “autumn-winter” collection to heat us up Evil
Ehehe!
OL Contest 2019
GIVEAWAY: 1 / 2
Lights-Out
Lights-Out's picture
Last seen: 1 month 1 week ago
It’s been awhile since i been on the forum but I placed a order 1-2 weeks ago for a led and has not shipped yet ? Does it normally take this long from RMM
Tom E
Tom E's picture
I would say that's not normal, specially if you ordered something listed as in stock? He lists availability and qty. I would say 1-3 days is normal, unless he posts he's on vacation or something. I would try reaching out to him. He's really not on BLF anymore.
MtnDon
MtnDon's picture
Last seen: 5 hours 42 min ago
Yes, I would make an inquiry. I received an order Friday for a few led’s on mcpcb’s and a driver that had to be flashed that I ordered last Monday.
Lights-Out
Thanks guys it was just a led on a XHP70.2 sent few messages on there site hope it come soon
pennzy
pennzy's picture
Last seen: 10 min 13 sec ago
All the D4V2 s are out of stock. Wonder what’s up.
Tom E
Tom E's picture
pennzy wrote:
All the D4V2 s are out of stock. Wonder what's up.
He shows qty 58 in stock - the tailcaps are out of stock ??
MtnDon
MtnDon's picture
Some color and led combo’s are out of stock, but there’s nothing sinister about that.
pennzy
pennzy's picture
I’m not able to select any emitter choices for the the D4V2 without a window popping up saying out of stock. Am I doing something wrong?
Edit : the 219 s are in stock only
saypat
saypat's picture
you are correct. Only the 219Cs are in stock.
id30209
id30209's picture
Last seen: 4 hours 43 min ago
WTB  Jetbeam TCR1  &  Titanium 47 2xAA Quark
dorpmuller
dorpmuller's picture
Last seen: 4 hours 54 min ago
He just got more stock of Emisars FYI.
"I am the flashlight king! I can light anything!"
Photonica
Photonica's picture
Last seen: 15 hours 14 min ago
Good to see the restock, now I can place an order.
I wish there were an option to either hide “Out of Stock” items or sort them last. It’s annoying to page through them when looking for something.
It would also be great if you could search Drivers and MCPCBs by diameter.
More Photons!
wolfstyle
Last seen: 11 hours 52 min ago
+1 on the driver by diameter filter.
