The existing Astrolux extender works in parallel not series with MF01S just like with original MF01. You will need to buy additional one end cap and have two loose battery cages since new MF01S changed design with integrated battery holder.
Does an expanded tube help with heat dissipation?
Or, with 8 batteries, does the lamp adjust in high / turbo mode just as fast?
The vast majority of the heat is at the far end of the head, above the switch level. So the battery tube heat dissipation is very small. I doubt you will see much heat related difference with a longer battery tube. Any difference will be tiny and you might not notice.
Turbo stepdown should not change.
Depending on batteries, you might see brighter Turbo output which means it could heat up faster.
I think the main goal of using 8 cells is just longer runtime. All run times double, except where heat might cause it to ramp down.
I have two MF01S (4000K and 5000K) using the astrolux extender tube (about 20€) and they work nicely! The original MF01 worsk with it as well and the MF04 ditto.
No Problems whatsoever.
The main advantage is longer runtime. In real world I don’t see an output advantage (i.e. more light on turbo) but turbo can be maintained a little longer…
But be aware, this then is a heavy flashlight and no beauty since the tube is nearly as thick as the emitter end
Cool just extender tube, extra caddy, and tailcap in… hooked it all up and yeah works just great. Yeah its mostly about runtime… I’m pretty sure output is a bit higher as well. I can’t really see a difference, so its not huge deal, but just based off heat its driving leds harder. I had setup ceiling to be at point where light just was slightly warm in hand, was like level 100/150 or something. Switching to extender tube same level is now noticabely warmer, so more amps must be flowing due to smaller voltage drop with twice batteries in parallel.
My Mf01s came without the physical reverse polarity protection rings.
Did they change the design? Does anybody else have a Mf01s without it?
In this vietnamese youtube review of the Mf01s it seems to be the same:
youtube link
Mine came also without reverse polarity protection rings.
Was delivered early december. So it seems they changed it quite a while ago.
Thanks for checking.
I bought four Samsung 30Q button top because I thought it would come with the protection. Would have taken flat tops if I knew before.
Well, I’m happy they work both, so I can use my Sony button top or Samsung flat top.
Mine was an early MF01S and it has the protection rings.
Thats not good that the newer do not have it. That was the best polarity protection rings on the market, because they works also with all flat top batteries. E.g. from Samsung, which has the contact lower than the heatshrinktube around the flat top.
I will find out from them next week.
My MF01S was purchased after the first round of colors was long sold out. I bought purple when the colored became restocked in Beginning of December so mine is very newer. I use flattops VTC5A. Mine has two rings down inside battery tubes on positive posts, but none on the tailcap’s end. I watched Flashaholics video and his had two on the tailcaps positive posts. It seems Astrolux did this inconsistency and should send ones missed. Every time I read threads on this forum I find more issues with their stuff.
I dont see the problem, everybody buying this light should be able to insert 4 batteries correctly. Otherwise this light is too dangerous anyway.
Make sure for instance all 4 batteries are fully charged to the same level when you insert them, otherwise it could get really nasty…
People expect to get what they paid for. Surely you understand what it’s like to buy something and parts are missing. It’s irritating.
my flashlight stopped working in smooth mode, only in steps, switching to smooth mode and it stops working or blinks until you disconnect your head from the case. Correspondence with the store where I bought it until I solved my problem … maybe someone already encountered a similar problem?
I tried to reset it, but nothing comes out, even the reset is not done.
I’ve never heard of this. Was it blinking out the voltage level?
What was the the stores solution?
it behaves differently for me, now the smooth mode does not work, it used to not work at all, and even earlier there was a smooth mode, but only with incomprehensible jumps (trembled). If you briefly live your life
and it all ends with a hang … he just starts blinking and does not respond to any actions other than blackout.
the video shows this hovering and not working smooth mode. When turned off, 3 clicks shows the charge, and when turned on 3 clicks on smooth mode as you can see, it immediately turns it off.
As for the store … the store is still delaying the solution to my problem: either they have a new year or a lot of calls, now they say that they solve my problem with the supplier.
The behavior in the video is something I’ve not seen. I would say the driver is messed up and needs replacing. If you can’t replace a driver, they would need to send a replacement head.
Thank you, my guesses were justified, I just thought maybe it wasn’t him, but now I understand that he’s really rejected, I read there was already a problem with the driver and just like you say the store replaced its head, but in my situation the store pulls with the decision, I will wait for them to decide. Thanks again
that the strangest thing was that he came without a defect, but after not using it for a long time, he began to die slowly, after each use his behavior was getting worse and worse, then completely stopped working, then after lying down a bit I tried to turn it on and it started to work, but it hangs periodically I repeat, the smooth mode stopped working. As soon as I wait for the store’s solution, I will definitely write it off.
