Hello! We have a new promotion for you!
Make an order for more than $ 100, get flashlight WIZARD MAGNET USB CREE XP-L WHITE as a gift!
Promocode: Cristmas.
Validity: December 20-23.
How to use:
1.Make an order over $ 100.
2. Apply promo code Cristmas.
3. Write the type of light in the comment( warm light, white light).
4. Get flashlight WIZARD MAGNET USB CREE XP-L WHITE for free.
I already bought two of the Wizard Pro Nichias last week. Hoping to see good rosy NW tint. I own dozens of Armyteks but not many Zebralights and the reason is because the emitters in the ZL usually have green tint so Im afraid to buy anymore. Armyteks also have tint lottery and I recieved a few with greenish tint but the majority are rosy. I hope Armytek will update their current line of flashlights with this Nichia 144A emitter or release new flashlights with this or even Cree HI cri emitters if the tint is not greenish.
Greetings!
We hope that you are in a good mood and February brings you joy and lovely weather. Let start this month with a profitable promotion. For every Pro version flashlight in the order you get Armytek Prime C2 Magnet USB XP-L Warm for free. High Power Flashlights - Armytek LED Flashlights | Armytek.com
Have a nice time purchasing!
*If your order contains several Pro version flashlights our manager will add Armytek Prime C2 lights directly to your order.
Use promo code “Hello” and get Armytek Prime C2 Magnet USB XP-L Warm for free.
Valid time: till February 9.
Great news! Now you can use Armytek Wizard multi-flashlight when hunting or fishing! Impressively powerful new Wizard WR with white and red LEDs and wide beam angle 70°:120° is an indispensable companion for everyday use and a compact assistant in solving specialized tasks. Suitable for tourism, active leisure, cycling, hunting, fishing, reading maps, observing wildlife.
• 4 LEDs: amazing beam of red light up to 250 OTF lumens and white light up to 1000 OTF lumens thanks to 2 LEDs for each color
• 5 brightness modes for each color, easy operation with one button and double click for switching between white and red light
• Convenient wide beam of the TIR-optics, protected from scratches by tempered glass with an anti-reflective coating
• Innovative technology allows to use any 18650 batteries and provides full protection against short circuit even in case of contact between magnet connector and metal objects
• Active real-time temperature control to prevent overheating and warning indication of low battery level
• Total protection from water, dirt and dust — flashlight continues to work even at 10-meter depth
What is the difference between Prime and Partner models?
Prime is an EDC flashlight. It has a side button, flat bezel as well as flat tailcap for vertical stand; Pro models have magnet in tailcaps for more comfortable using. (https://www.armytek.com/flashlights/models/prime/)
Partner is a tactical flashlight, but it can be used as an EDC light as well. It is compatible with remote switches and weapon mount, has strike bezel and tactical button; Pro models have both tactical and side button. (Small Tactical Flashlights - Armytek Partner | Armytek.com)
Hello! The most popular flashlight the Wizard. At the moment we have four models of the Wizard and now we compare it. All flashlight have sphere of usege, for example: fishing, hunting, camping, car repairs, and other. Here are the brief description of the lights.
P. s. there is a hidden promo code( with 30% discount on the all product) in the text.
ARMYTEK WIZARD MAGNET USB
Brightness up to 1000 OTF Lm.
Beam distance up to 119 m.
Up to 100 days of light with one power source.
ARMYTEK WIZARD PRO MAGNET USB
Brightness up to 1800 OTF Lm.
Beam distance up to 130 m.
Up to 200 days of light with one power source.
ARMYTEK WIZARD PRO MAGNET USB NICHIA LED
Brightness up to 1400 OTF Lm.
Beam distance up to 97 m.
ARMYTEK WIZARD WR MAGNET USB
4 LEDs: amazing beam of red light up to 250 OTF lumens and white light up to 1000 OTF lumens thanks to 2 LEDs for each color.
5 brightness modes for each color, easy operation with one button and double click for switching between white and red light.
Beam distance up to 97 m for white light and 41 m for red light, up to 15 days of light with one power source.
Hello! We know that you like Quiz. You should to answer the questions. If you right to answer, we give you promocode with discount.
The first person to answer the question correctly will receive a promo code in message.
P.s. promo codes are valid until March 1
Questions:
What the flashlight: he has beam distance up to 15 m and 5 years no-hassle warranty? (discount 5%)
How many motes the flashlight Elf has? (discount 10%)
Which depth can the Prime lights be submerged? (discount 15%)
Which battery we use with the tactical flashlight Viking Pro? (discount 15%)
How many lm Tiara C1 Pro magnet USB flashlight has? (discount 15%)
What Doberman Green flashlight weight without a battery is? (discount 20%)
What is the hotspot:spill of the light in headlamps? (discount 25%)
What is included in complete set of Barracuda flashlight? (discount 30%)
What is the length of the flashlight Partner C4 Pro? (discount 35%)
The Candela Peak Light of the Wizard Nichia?(discount 40%)
*Please keep in mind that promotions and promocodes can not be applied together.
For any help or assistance feel free to contact us.
