I haven’t hard yet, but at least uneasy.
The bezel doesn’t come off and is likely glued or held with a press-fit shim.
And I should note I’m bad at opening lights other than the easiest.
Mmm, maybe you can try dipping the thing in some white spirit or turpentine, that should dissolve any glue in a few hours (white spirit will damage any o-rings, be warned).
Thanks a lot for the video.
Simple…bit I haven’t tried that before.
Now I did - and it didn’t work, even with significant force, I only managed to scratch it badly.
The interesting thing inside is LED which needs to be swapped to make this a really good light.
there is no way to be sure with those inexpensive brands, it is always a lotto. but in this particular case, it is certainty 99,9% you will get new holder, they seem to stop making first gen holders
i stopped using all my oem holders and bands, i print my own, and i use 35-40mm bands. for d10-25 as well as zebralight and skilhunt.
if you can print, you can find stl in this thread, [Review] 77 Outdoors D25 Headlamp (18650) and it is tested and it works great, just print it on the side,
i also designed my own holder for d10-25, as well as zl h600. i have no way to post stl here, not i have acct at stl hosting sites, but if interested pm me i’ll email you stl.
btw, you can heat up 2nd gen holders grips and bend them in tiny bit, and it will hold just as good as 1st, i tried it and it worked great, using a construction heat gun, but i set it too high, and edges started bubbling, but it still held the light firm.
JasonWW I doubt white spirit will have any detrimental effect on a driver board. You can also try with gas, after all white spirit is similar to gas but with 0 octane rating. Just don't dump that gas into your car's tank afterwards… :-D
Do you mean that gen 1 is good and gen 2 is bad?
Are all companies that manufacture these lights using the same holders?
I’ve wanted to try your holder for some time already. My employer purchased a 3D printer a week ago and I hope I’ll be able to use it. Anyway, I know that I like the current holder and I don’t yet know if I like yours - and I would surely want to order something that works.
Yes, 1st gen had thicker grips and gripped a lot better. it looks like every light of those types no matter the brand come with identical holders
the stl in the link i posted isn’t mine, it was designed by gchart. mine are for wider bands. they are larger and thicker, i’ll post pics when i get home.
molded plastic is much stronger than printed, (i have not tried polycarbonate, or nylon, or carbon fiber filled filament, they supposed to be stronger, but my printer can’t handle them) i have tested several designs, printed in different positions, from different materials, (petg, abs) , as well as oem. i bend them to the point of braking, that is why i designed mine to be thicker, and larger then oem, Gchart’s design is strong enough to last a long time, if printed on the side, (layer orientation matters a lot, as far as strength) uses original rubber strap. he also designed one for wider strap.
Fact is it is better to be flexible. So, if you stopped buying USB A to micro-B cables you are better buying converters. After all, the USB micro-B connector is smaller (takes up less space), cheaper and perfectly adequate for (at least) up to 12 - 18 W of power.
I also hear that cassette tapes are adequate for playing music. 6 volt positive chassis is an adequate electrical system for automobiles. The bow and arrow make an adequate weapon. Horse and buggy make for adequate transportation.
Just because something is adequate doesn’t mean progress should stop.
