I’ve seen solder wick broken so many times I won’t use it for a bypass, don’t even own any. I use Turnigy wires and always try to put a bit of a coil on them so they compress rather than bend.
I don’t like button contacts on the driver. I consider it much better to have springs at both ends of the light.
That way you don’t get a momentary disconnect if you drop the light on its tail and the cell pulls away from the driver button as it bounces on the tail spring. Those momentary disconnects create an unwanted mode change on lights with reverse clicky tail switches and a half-press mode change UI. Really annoying if your light just went from moonlight to turbo or vice versa.
Springs at both ends also help to prevent “cell hammer”, which is what happens after a really nasty drop where the tail spring propels the cell back into the driver with such force that the driver PCB cracks and kills the driver.
Spring bypasses with multi-stranded flexible silicone-insulated wire are the value option, and double springs (as you said) are the gold standard.
I was asking because I needed to illuminate dark basement while working for few hours, so I was thinking about putting the flashlight into glass of watter to keep it cold, so it could run on turbo for infinite time
Could anybody tell me the diameter of the battery tube? I want to buy one shockli 21700 4550 22a/30a for the s21a that is coming but I think it will be too thick.
Nice it has a true Constant Current FET driver, but a shame a 10% mode was sacrificed for a moon mode.
In fact, it seems all Convoy drivers have sacrificed a necessary mode for a moon mode, ruining the mode spacing.
Finally got my first S21 from banggood this week. I don’t hate the 6500K as much as I thought I would, and I love this light. I EDC a Jaxman E2L, S2+, or BLF A6 in cargo pockets, and after a few days with the S21, it really doesn’t seem bigger for my carry purposes.
And the idea of a 5000mah 21700 with a full day of runtime makes me giggle as much as the throw of SBT90 in my new FT03S.
When there’s a version with a warmer tint and biscotti, I’m definitely getting another one of these. Ah, who am I kidding, I’ll probably buy more just like this when they go on sale again. Just an amazing deal for $17.
You could probably also ask Simon to install and XP-L HI of your choice into the light as well. They match well with the driver, I swapped one into my S2+ with 5A/12 group driver and am enjoying it for a cheap beater light.
Hello guys, I have a question about Convoy’s 4-modes driver.
S11 with 4-modes driver, no strobe mode listed in the specification/description at AliExpress Convoy store, but some reviews on BLF mentioned it actually has strobe mode.
What about S21A ? Is it also 4-modes plus hidden strobe?
The S11 XHP50.2 driver manufacturer mistakenly added the double-click strobe function when producing a batch of drivers.
As a tool for daily use, I personally don’t like to add strobe to modes
