You should get 200 or 250 lumens with that current. At lower currents the XHP50 is quite efficient as it has a quad die which behaves like four seperate leds.
I guess the blinking of the bike strobe doesn’t take much more current as it is rather short. With your vision adapted to darkness 200 lumens can be pretty bright.
Thought I’d share a little tip… don’t know how many people here are aware of it. But it’s nice to know.
One NetFlix account allows 5 devices. And they can be in different locations. There is no mandate that the devices be owned by one person. Their own site language mentions “family.” But even if you let a friend use it, there’s no way for NetFlix to check (of course, you have to trust that they won’t lend out your account to anyone else!).
So if you have a family member with a NetFlix account and you’d like to also enjoy it, ask them to share.
I discovered that this worked because while I’ve cut the cord, I wanted to have Internet access to content. When my mother upgraded to a smart TV, I inherited her old Roku. It still had her NetFlix account info stored. So I could watch NetFlix with no problem! She wasn’t getting any extra billing while both devices were simultaneously active. I was a little worried I was doing something illegal and didn’t want her to be hit with extra charges suddenly, so I looked it up and found out this great news.
This is pretty common knowledge and folks have been doing it for years. Technically, they would be able tell you are doing this since it’s pretty easy to see what location you are logging on from via your IP address (unless you are using a VPN). However, I’ve never heard of anyone getting shut down and I don’t think they actively pursue people who share accounts.
Just so you are aware, it is technically against their terms of use to share an account outside of a single household.
“The Netflix service and any content viewed through our service are for your personal and non-commercial use only and may not be shared with individuals beyond your household.” https://help.netflix.com/legal/termsofuse
There’s no good reason to announce that it’s “common knowledge.” I didn’t know about it. A couple friends of mine didn’t know. I assumed that there might be other people here who don’t know about it. So that’s why I shared. In case someone else didn’t know. That’s called sharing useful knowledge in the hopes someone else gets something out of it. Do people tend to do that in your neck of the woods?
And by the way “household” is a loose term. If you have multiple homes, you don’t require multiple NetFlix accounts. You leverage the same account. A family member residing in a different home can still use that account, as long as not more than 5 devices are shown streaming from it.
I wasn’t trying to be derogatory; no need to get defensive. The point I was trying to make is that the majority of users do know about this and in fact take advantage of it. There was a big scare a couple years ago when some information was leaked leading people to believe Netflix may be cracking down. They were not, but it brought the issue to public attention.
You could probably get away with sharing an account between family members but sharing with friends in different geographic locations is almost certainly a violation of their terms. I won’t tell you what to do, just wanted you to be aware. That’s called sharing useful knowledge, as you said.
Is there a list of flashlight manufacturers by country available ?
Also, are there any flashlights that have actual lumen output measured as advertised that can be purchased publicly ??
Are you asking about companies or manufacturers? Almost all manufacturers are in China. So that’s pretty simple.
There are some flashlight companies headquartered outside of china, but their lights are still manufactured in China.
The only lights I know actually made outside of China are small specialty makers who do very low production and charge extremely high prices.
I don’t know of any list.
There are lots of lights that are accurately rated lumen wise. This is on a model by model basis, though. The best thing to do is not trust ratings. If there’s a model light that you like, read reviews and see what the actual specs are.
And then add a fat margin because our measuring devices are more inaccurate than we like (but give at least a ballpark indication which is not always the case with manufacturer specs)
I dont really think that. Measuring amp draws plus using a lumen tube or sphere calibrated with a Maukka light gives a pretty good lumen reading. Lumens are still pretty hard to measure, though.
Things like lux are much easier, so reviewers can give pretty accurate throw numbers.
The main thing is don’t get hung up on specs and numbers.
Calibration with maukka’s lights has brought a huge improvement with getting measurements in the same ballpark (not every reviewer has done the maukka calibration though, and they also produce lumen claims), but both for lumen measurement and lux measurements, a correct calibration does not fix spectral errors that are caused by cheap luxmeters and by spectrum-altering diffusers that are widely used, this can introduce errors of up to 15% for throw (to give an idea, a throw claimed to be 400kcd could actually be 340kcd) and with an added diffuser-related error for lumen measurements (my own integrating sphere that I tried to design to have only limited spectral effects, already warms the light up by 500K, and makes calibration-unrelated measurement errors as high as at least 4% depending on the light spectrum of the source), all especially when very cool white light sources are measured, like the White Flats and SBT-90.2.
Match= If you have a lumen tube or sphere that’s calibrated with one of Maukka’s lights then I think that’s good enough. If it’s a light with a FET driver then the battery will make a difference.
