I was out walking around the rim of a large detention pond the other night and tracking varmints in the grassy bottom. I'd say 1000' is realistic.
I really appreciate you checking for me. Bummer I missed another raw BLF edition, any hope for a second batch? Looks like I’m off to hunt for this one in the marketplace.
no time to read the whole thread. Does the sst40 have any green in the beam? Are they about the same in throw and how far?
Thanks for any responses.
I took some quick measurements. Keep in mind this is just my example of the light, but I have had two different D80v2 SST40 heads (first one had some issues but Jacky took care of me) and they both had similar tints. Also ignore the lux measurements because I haven’t calibrated that yet.
Color temperature shifts a bit cooler as current goes up and it loses some of the green tint.
Do they have any xhp50.2 version in stock?
I bought one from Nealsgadgets last month and he put it in the post the next day, so he might still have some left in stock.
https://www.aliexpress.com/item/4000333646371.html
Does anyone know the candella rating for each of the 3 types of emitters?
thanks
Can I ave the code please?
thanks
thanks
Have you seen this thread “”BLF D80v2 (WildTrail) now at nealgadgets @ $27.70 (coupon: NDD80V2)“:https://budgetlightforum.com/t/-/58318”.
Ok thank you
thanks
Thanks guys
Just curious, where can i find a replacement driver for the Wildtrail D80v2? (I have one with a faulty driver, (only glows & flickers dimly)
I would try to pm tatasal to see if he can set you up with a free one or at the very least a good source.
DBSAR:Just curious, where can i find a replacement driver for the Wildtrail D80v2? (I have one with a faulty driver, (only glows & flickers dimly)
Actually i managed to fix the driver, found a cold solder junction on the FET.
Code for d80v2 pls
Bit of a necro but thought this might be useful for someone.
Mode groups image courtesy of DB Custom (ignore the arrow). As mentioned already in this thread, default is mode group 12.
Below is info on how to interpret the groups (from TA’s driver thread ).
For reference :
Moon = optional in menu and not shown
ONE7135 = 8
ALL7135s = 14
Turbo = 20Modes approx mA and lumen values for single XP-L LED
1 = 5.5ma = .5lm
3 = 19ma = 4lm
4 = 37mA = 12lm
5 = 66ma = 24lm
6 = 135ma = 60lm
8 (one7135) = 355ma = 150lmAbove this it will depend on how many 7135’s are installed
With 7× 7135
10 = 640mA
12 = 1A = ~335lm
14 (7× 7135) = 2.55A = ~830lmAbove this you are using the FET and it will vary wildly depending on the build.
16 = ALL7135s + 25% FET
18 = ALL7135s + 60% FET
Turbo = 100% FET
Dark brown is nice :+1:
.Is it possible to have a 21700 tube option ?
+1 to this. I don’t mind if the tube is a bit bigger - in fact, it would be preferable.
Just wondered, for the no-ano folks, how did you get on with cleaning up / deburring the battery tube? Or did you just leave it alone?
