The big chip has nothing written on it…
The chip ont the bottom right says Mc811
The chip next to the big chip just says S4
i think the big chip could be the processor for the modes of the light high low etc
the a1shb is some kind of fet device and i belive its for the power
but its recomended applications are for something else
im kind of lost and this problerly needs someone more experienced in electonics then me, i studdyed a long time ago
chris
Thanks for your help anyway. Maybe someone Else knows something. Is it possible to swap the driver for something else instead?
That’s not a 7135, this is:
This XML T6 looks like a cheap chinese copy. You should replace it with a genuine XML2 or a Luminus SST40. Make sure to use thermal paste underneath the led.
To increase the output you could add one or two resistors on top of the four 1R0 which should be the current sense resistors and responsible for the high mode. If you add resistors be careful because too much current could fry the driver or the led.
If you want higher quality flashlights have a look at Sofirn or Convoy on Aliexpress. Those generic zoomie flashlights are quite bad in both manufacturing and performance. If you are determined enough to put in a new led and driver and maybe some copper to improve thermal properties you can actually turn it into a quite decent flashlight.
The resistors are 1R8 but i guess the advice would be the same?
What kind of flashlight would you recommend? By the time i get a flashlight and swap led, driver and cooling, can’t I just get all those parts and get a flashlight case for that?
I was also thinking of building a flashlight from scratch and I really would like to do that with the XHP 70, but i guess this would be pretty hard because of the high heat output. Any recommendations here?
Yeah, sorry, but any cheapie light that still has “XML T6” on it is likely garbage.
There are so many decent lights out there (even on Amazon) that would likely be cheaper and better vs just trying to mod/replace the driver. Nonzoomie, but look up the FC11 or SC31 if you want a great light with onboard charging.
Anyhoo, before anyone says “Just shut up if you don’t have anything to contribute!” , you can bypass those 4 “1R0” chip-resistors (its “regulation”, if you could call it that) which make up a ballast resistance of ¼Ω with a few more on top, reducing the resistance a bit more.
You’ll still have whatever Angry Blue™ LED is in there, but at least you’ll be pushing it harder.
Convoy c8
Perfect for mixing and great starter light
Xhp50 in and it throws
I just ordered some resistors and i will try my luck.
I really like tinkering with this stuff, so i don’t mind if it doesn’t get me the best experience from the start.
@ forsh how big is the difference between the xhp 50 and the xhp 70?
I already ordered a xhp 70 a few days ago, and i would really like to try it out, I only need a case for it and the convoy c8 only accepts one 18650 cell and i need two.
Now that you have the flashlight you can try to improve it. 1R0 is 1 ohm, 1R8 is 1.8 ohm. Those big resistors in parallel with an R on them can be easily recognized as the sense resistors that limit the high mode. Adding resistors or bypassing them like Lightbringer suggested gives you more output on high.
I would recommend you the flashlight hosts from Sofirn or Convoy as they are manufactured a lot better than any generic flashlights. You can also get the leds and drivers at the official Convoy or Sofirn store on Aliexpress. Assembling those parts is an easy start to modding flashlights.
For the XHP70 you could have a look at the C8.2 host with 10mm reflector led hole on Aliexpress: Link
The XHP70 is difficult indeed because the heat it produces has to be transferred to the flashlight or it will overheat. That is valid for every led though, it is just that the XHP70 produces a lot of heat.
the xhp70.2 is 7mm
the hp50.2 is 5mm
the xhp70.2 is 12 volt but you can get a 6volt version
there is some 3volt xhp50.2 , i have one in my convoy c8
you need to change the driver in the convoy to a 6volt driver for the6v xhp70
it will get hot! very hot
there is extension tubes for convoys so you could put 2x 18650s in
i wish you look and tell me how it goes
for the driver there is a guy from germany on this forum LEXEL
pm him , he does drivers for convoy c8 . he is super cool andyou can ask him to custom make you one
i ordered from himand it came to finland in 3days
the software on the driver is good, the workmanship he does is second to none
you can have it kind of drop in or if your good at soldering ,you can solder the wires and spring yourself
All the XHPs (except for the new’n’special 3V ones) are 6V or more. If you could get a boost-driver to fit, it’d work.
Beware, though, that zoomies in general do not have the best thermal path, so what might work great in a regular tubelight or plunger-light, will likely build up too much heat in a zoomie’s LED.
And if doesn’t have a solid shelf but a “hollow” one (sits on a ridge/ledge instead, big gaping hole in the middle), it’ll be even worse.
If I get this host, is there anything I can improve on it thermally, so it is better suited for the xhp 70?
Or do I just have to get a good host in the beginning and then get a fitting LED?
This host is already pretty good thermally with an integrated shelf and deep cooling fins. You should use a 20mm copper PCB for the XHP70 with a good thermal paste underneath. The driver would need to be 22mm.
I just ordered the host, now it only needs to arrive.
Do you have any Suggestion, Where i get decent cree LEDs, not the nockoffs and Also decent drivers for them?
Can you sugfest me a driver for the xhp 70, or what am I looking for?
The convoy C8 with the xhp50.2 what’s the output and current?
Today the resistors arrived. I added 4 of the new resistors on top of the old ones, but i don’t think it did much.
I now measure 1.3A at the LED. Can I add more resistors, or is that too much for the board?
Ok I just kept adding resistors, until the current at the LED didnt change anymore. It runs at 1.75A now and is noticeably brighter. It also gets a lot warmer than before, so i think i will leave it here. The other parts are ordered, I will keep you posted once they arrive.
The XHP70.2 is normally not sold as a bare nockoff, you will find those mostly in flashlights. One source for XHP70.2 is Kaidomain or you can search for XHP70.2 on Aliexpress. For a genuine XHP70.2 in the brightest P2 bin: Convoy flashlight store
The XHP70 needs a driver with 6V and 5A. You can buy a boost driver that is used with one battery (1S) or a buck driver for two batteries. 1S boost driver 2S/3S buck driver
