Driver works at 4A (max) and I can’t see flickering PWM.
It has temperature protection like new Convoy Drivers.
Great light! This seems to be the “natural” evolution of their VG10!
Flashlight alone according to BG site.
From what i understand:
Configuration mode:
5 groups:
Double-click to enter Strobe in any modes.
Image via AMUTORCH buyer
Not working, I can’t change between different group modes. And can’t enter to strobe.
My XT35 is not like your photo. It hasn’t written XT35 anywhere, only B35 on head
freeme:Flashlight alone according to BG site.
Kit Latura:Mine has arrived without manual. Any idea where to get it? What is supposed to be inside the package?
Operation:
Configuration mode:
- 5x quick half press and release (when light is in ON state).
- Flashlight will flash 1x > 2x > 3x > 4x > 5x time sequence. Number of flashes correspond to the group number.
- Turn OFF the light to select your preferred group. ( example: to select group #2, turn OFF light when XT35 flashes twice.
5 groups:
- 2000lm
- 2000lm - 10lm (default)
- 2000lm - 400lm
- 2000lm - 1200lm -10lm
- 2000lm - 12000lm - 400lm -10lm
Not working, I can’t change between different group modes. And can’t enter to strobe. My XT35 is not like your photo. It hasn’t written XT35 anywhere, only B35 on head
Does it goes into configuration mode >>> 5x quick half press and release (when light is in ON state)?
Kit Latura:Not working, I can’t change between different group modes. And can’t enter to strobe. My XT35 is not like your photo. It hasn’t written XT35 anywhere, only B35 on head
No
Strange. Are you able to switch between different light level? Do you recognize any of the stated grouping?
This should be the updated one.
5 groups:
freeme:Does it goes into configuration mode >>> 5x quick half press and release (when light is in ON state)?
No
quote=Kit Latura]
No
Maybe 2000 - 400. Not 2000-10 of default mode. I’m sure about this. Strobe mode still inaccessible
My switch is forward clicky. It’s right?
Do you have a soldering iron? I just realized that there are two type of driver for this light on AMUTORCH TaoBao.
The list that i have posted is for Daily Mode firmware. Very high chance that your version is Tactical Mode version, which requires you to manually select the group by bridging the pads shown in pic. Are you able to check yours?
freeme:Strange. Are you able to switch between different light level? *Do you recognize any of the stated grouping?*
quote=Kit Latura] [quote=freeme]
[/quote]
NoMaybe 2000 - 400. Not 2000-10 of default mode. I’m sure about this. Strobe mode is inaccessible
If remove the bridge there’s only the high mode.
With the pads bridged, it have group mode of 2000 and 400 lumens, again.
there is some solder in the red area. Can it have something to do with it?
Seems correct, no bridge equal to group #1, single mode at 2000lm.
If remove the bridge there’s only the high mode. With the pads bridged, it have group mode of 2000 and 400 lumens, again. !Telegram: Join Group Chat! there is some solder in the red area. Can it have something to do with it?
You tried soldering the grouping that you want? Or you mean you can only get 2000-400, despite bridging a different pad?
Kit Latura:With the pads bridged, it have group mode of 2000 and 400 lumens, again.
When soldering pads number 5, now I have access to this group of modes.(Hurray!) . But flashlight still without strobe mode
Not able to switch mode groups either. Same issues as Kit Latura
Do you have a soldering iron? I just realized that there are two type of driver for this light on AMUTORCH TaoBao. The list that i have posted is for Daily Mode firmware. Very high chance that your version is Tactical Mode version, which requires you to manually select the group by bridging the pads shown in pic. Are you able to check yours? [image] [/quote] No Maybe 2000 - 400. Not 2000-10 of default mode. I’m sure about this. Strobe mode is inaccessible
The ability to hard code the mode selection with solder and no strobe mode makes this light much more interesting to me. Too bad it’s already sold out
Freeme, any chance we can reboot this deal? Or the new XT40 TIR version? Price target under 40usd, preferably 35!
I see these on TaoBao for around 200-250 yuan, which is an affordable price. Amutorch is charging waaayyy too much for their lights recently through other outlets.
XT40
https://item.taobao.com/item.htm?id=625402652240
XT35 w/ PM1
No intention for Aumtorch.
Freeme, any chance we can reboot this deal? Or the new XT40 TIR version? Price target under 40usd, preferably 35! I see these on TaoBao for around 200-250 yuan, which is an affordable price. Amutorch is charging waaayyy too much for their lights recently through other outlets. XT40 https://item.taobao.com/item.htm?id=625402652240 XT35 w/ PM1 https://item.taobao.com/item.htm?id=606701694998
