Respectfully… I feel like it’s still around largely because it’s what the manufacturers know and are accustomed to using.
As far as being more complex… sorta. There are more pins that can be connected, true. Like MicroUSB, though, you only need to connect two pins (power and ground) in order to charge a device… so long as you’re using an A-to-C cable and not a C-to-C cable. In that sense, the jacks are practically a drop-in replacement.
But in order to handle C-to-C cables, you do need two extremely cheap resistors (like $0.0001 or less in bulk) in the device attached to a couple of the pins so that it gets properly identified as the receiving end. Is it an extra measure that needs to be taken? Sure. Is it really that much more expensive or complicated? Naw.
Now if you want to open up the can of worms that is QC2 vs QC3 vs PD, etc… ugh. But there’s no reason to in a flashlight as long as you don’t need a high charge current/voltage.
Now don’t go raggin’ on Horse and Buggy man.
When the Electromagnetic KaaPows drop, the Horses will still operate.
Matter of fact the Amish have been preppers since before that term was even mainstream.
Organic food?, yep, Solar? Been there done that. Generators? Oh hell yeah, big diesel jobs.
They dig LED’s though, now their buggy batteries last for months without recharge instead of once/twice a week.
Some of the newer buggies can use Dewalt tool batts to run the lights, usually 2 of them in parallel.
They are much more tech savvy then most people realize and also understand all types of medical procedures and the equivalent natural options available.
One of my neighbors traveled to Germany for a back operation that the doctors here would not do because of liability and even after the airfare and lodging it still cost less and worked like magic.
By the way, out of my above posted adapters in #234 the ones from links 2 & 3 do not work for data transmission, tried them to connect an EBD-M05 battery tester to PC via type-C cable and failure. So beware.
Positive chassis? Lets skip that part. Even with negative chassis, 6v became inadequate due to the increased number of electrical items in cars. At 6v the wire had to be big which weighs more and costs more. With 24v you can use much smaller wire for the same power. So 6v was adequate up until the 50’s or so but soon became inadequate. We really did need to switch over to 12v.
Bigger military vehicles starting in the 50’s and 60’s have used 24v systems. A lot of aircraft also run on 24v. There was talk of regular automobiles transitioning to 24v to again reduce weight and cost since they are becoming so computer intensive.
I guess my point is things that were adequate at first sometimes become inadequate over time. That’s when you need to change.
If a thing is still adequate, then there’s no real rush to update it.
Transition periods are rough and tend to be put off for as long as possible.
I think in the case of the D10, the assembly line is already cranking them out with micro usb. Maybe the next generation of this light with all its other updates and changes they will have to decide whether to stick to micro or go C. I’m sure they will do whatever will sell more lights.
Some of you probably need to esteem yourselves a bit better and tame your egos in the process, there's already more than enough preceding off-topic messages here serving nothing really good with all that old standards discussion. A quality USB A to micro-B cable is a lot cheaper than the effort you are investing here to adamantly prove your point for really nothing good. I need no-one to tell me I'm right but if you do, then you're right.
My first D10 has arrived and it has the good holder. :partying_face:
And the bezel is not glued. :partying_face:
I can recommend this seller but do ask them whether they still have the same.
Now…I need some smaller TIR lenses, none of mine fits.
ADDED: has anyone tried sanding a 20 mm TIR lens?
That’s what I did shortly after I got my D10! Got a cheap 60-degree TIR optic (the sort that people usually get for a Convoy S2+), then sanded it evenly around the edges until it just fit.
I did also sand it a little at the base to have it more comfortably fit vertically with the bezel fully screwed down, but otherwise it worked fine!
Thanks.
I have a DC fix but I prefer to use TIR. I’ll try some filing later. I think that a 20 mm lens will do a better job than a 17 mm one. Though I do need to make an order at Yajiamei eventually and get some 17 mm ones anyway.
Lots of you went to the labor of replacing entirely the internals of this headlight. How much extra cost did that incur? Would it make sense that the manufacturer did that improvement right at the beginning? Saving the users the labor and cost thanks to the economy of scale.
Members here are tinkerers, they get enjoyment out of modifying lights and making them either better or more to their liking.
To some, this headlamp has a killer feature that I haven’t seen on any other: A metal shrouded, o-ring sealed, USB charging port. If you didn’t know it was there you might not ever realize it has USB charging! No floppy little rubber covers to fumble with and hope they protect the port.
The BLF purchases of this light amount to a drop in a bucket, making the emitter and optic changes at the factory would be great for us but wouldn’t benefit them at all. Any suggestion would probably be met with a laugh. If you look at the range of headlamps this company makes it will quickly become obvious that flashlight enthusiasts are not their target audience.
I gave mine to a flashlight buddy, it had worked faithfully for long hours at my job. I’ve got another on the way with a driver from Quadrupel for it and an emitter swap waiting.
It may double the cost of this $10 light but I enjoy the work and the results.
