** BLF LT1M-Mini Project - The little Lantern! ( PM's sent today June 21, 2022)**
Some first designs of the driver
as discussed one with a red channel the other with a Turbo mode
Diameter 25mm with USB-port has resistors to charge directly on a USB-C wall adapter
TP5100 up to 2A fast charging with 5-18V input (not QC or PD, but good for direct connection to 12V solar panels)
RED 3+3+1 AMC
DD WW+3+3
(Reserved 5)
Very nice! I love seeing your prototypes, Den!
I use my LT1 every evening and will definitely buy a couple minis.
Looking forward to more details and the introduction video! :+1:
Thanks for the comments :+1:
As we to get power outages quite often, the LT1 has lit many nights here, and i still use the first production one i received as my main night table light, running on moon or candle mode every night.
This new thread is dedicated to the LT1M Mini, which is the answer to the many wanting a pocket-sized, back-pack sized portable version for camping trips, and even be the little brother/sister to your full size LT1 Lantern. :smiley:
I’ll hold on until micro :sunglasses:
Awesome in for one in 4 years if I survive the pandemic :slight_smile:
I will be doing a video soon on some custom built super micro lanterns, even one that can fit in your wallet, emit the same light or more of a candle 360 degrees , & run for 40+ hours.
AWESOME. Hope you’ll link it on BLF
I will, it will be in the main OP of this topic for the LT1 Mini, but will be a separate new topic for the other micro lantern projects.
Woah! Wallet?? Never seen anything like that…
Yes, sort of. The entire lantern in only 4.5 millimeters thick, uses a very unique remote-phosphor LED (very hard to find) that emits Warm white nearly 360-degrees like an incandescent bulb, can run from a single CR2032 Lithium coin-cell for 12+ hours brighter than a candle, (tested) then run for an additional 30+ hours dimming down to a moon light, but this wallet lantern has two slots for two CR2032 cells in parallel to double those run times, (or save one as a reserve back-up cell after the first is spent.) I have one in my wallet now. the video will reveal this “24+ hour wallet candle” when i create that topic. :smiley:
Driver of IF25 use noticeable PWM.
Could it be possible to transform ltmicro into handheld flashlight? It seems much more actual question than for lt1.
Also for small host it seems good to use main host as heatsink.
we will be developing the LT1M Mini to use non-PWM same as the full size LT1 Lantern.
Interested
As with the LT I’ll be keeping the interest list for LT1M. Just post your interest in this thread and I’ll add it to the list.
Note that any interest posted in the prior mini LT thread was not captured so post in this thread to get onto the list.
Thanks
:+1: :smiley:
:+1: Interested
Interested
Interested
