Nice. I’m curious to know how it feels with the leather sleeve
I’m sure Justin would love your work here. Reminds me of the things he did.
Well, it feels nice and smooth, even in the part of the stitches, which are - naturally - more rough!
The sleeve gives a sense of continuity between the tailcap and the head, as it covers the battery tube and its grooves!
So far, even if hadn’t use it for a long period, I’m liking it!
BTW, that small part in the head, it will probably go out when I start using the flashlight clipped to a pocket. As it doesn’t have “walls” to stop it from sliding and as it is not super tight, it will probably go out in that situation!
Thanks for reading
Wow, that is very kind compliment
Even if I never met Justin here and only had the possibility to see his work in threads and videos, I feel that he lives through this forum’s works and members and in a certain I wanted to honour his memory with this mod. Even if it is not the most complex one, I feel happy for those words
Thank you!!!
So, Sunday I was bored and decided I wanted to do something for this modded light, that is almost finished!
I decided I could do a holster!
I picked some of the leather used to the host “sleeve”, a damaged leather belt, double face tape, orange paracord, a carabiner and a “stopper”.To make the holes I used a belt hole puncher.
I also attached the lanyard to the clip
I’ll let the photos speak by themselves!
Nice.
Thank you
Well done!
I like your consistent style. The leather on the flashlight tube and the leather of the holster leave no doubt that this flashlight belongs in this holster. The copper bead of the lanyard matches the orange cord as well.
Another very nice build thread with great descriptions, layout & images
Thank you
I tried to make things look like a “theme” with all the colours “matching” the overal set! I like orange and I think it was the best option for this mod, specially due to location/visualization aspects!
The holster is a plus but I thought it would fit well in the overall mod
The only thing that is yet to be assembled is the GITD gasket that has been delivered today and that I will probably put in this light tonight to finish the mod
Then…the beamshots :smiling_imp:
Thanks mate
Tried to do my best on that, even if sometimes I tend to mess up with too many photos
BTW, the gasket was delivered at my home today! I’ll see it later and gonna put it on tonight :partying_face:
I’m happy
Cool.
Never too many pictures, it’s all we can judge the entries on, unless you invite us all over to see in person
That would be a nice thing to do
But…for now I guess I will stay for the photos It is easier than having a gathering here ATM
I’m hoping for a sunny day and dark night to show you the “last” photos of this build tomorrow
Yesterday I received the last pieces for my mod
From CRX arrived a GITD gasket and a GITD tube (along with other stuff ) and as soon as I got them I installed them
The installation took me a while because the optics were not fitting the MCPCB very well, so I has to pull the MCPCB up, install the optic + gasket, and then “unglue” the driver to pull the wires down again. Then I mounted the head and glued the driver again
I also installed the GITD tube in the holster adding an extra piece of thinner “paracord” in 2 empty holes. I opted to put it in that place because it will help me on locating the holster if needed.
Later I will try to take some photos of the all “modding” set But for now…enjoy
And it all worked after the rebuild. Nice.
Looks very nice, good job MascaratumB!
Nicely done.
Thank you all for looking and for your comments folks
And thank you for the inspiration that directly or indirectly you’ve been giving to me and to BLF member along time! “Drinking” from your knowledge and from your builds and mods was something that also helped me through this small modding path
The process of modding the Amutorch VG10 is now finalized!
In this post you’ll find (many) photos of the final products and also my balance of it!
I will also pick my initial modding aims and check what was done and what was not
Here:
This flashlight was: | How I wanted it to be? | What it is! |
- Forward Tail Switch | 1- Forward Tail Switch 2- Orange or Green tail cover 3- Bistro UI 4- 22 mm driver 5- 6- 7- Carclo 10622 or 10621 8- 9- Leather handle 10- Glowing gasket 11- GITD piece inlaid in the tailcap 12- some extras to be thought :p |
1- DONE 2- DONE (Orange) 3- DONE (configured on mode 9) 4- DONE 5- DONE (Luxeon V) 6- DONE (led4power) 7- DONE (Carclo 10622) 8- DONE 9- DONE (call it “sleeve”) 10- DONE 11- DONE (orange tritium vial) 12- DONE (copper bead + lanyard, wood support, holster) |
From this to that!
MY BALANCE
What can I say?
It turned out better than I could have thought!
In the beginning I had the intention to modify a flashlight, and then I ended up modding it and “building” some other stuff creating a set.
Some important points from this process where I:
- used several tools I had used before and bought new ones and learned how to use them;
- borrowed my father’s help and tools in one occasion;
- worked with materials I never used before, specially leather and waxed thread;
- made some “stitchery” in MtnDon’s words (sewing and stitching) to make the flashlight sleeve;
- made a copper bead;
- installed a tritium vial for the 1st time;
- recycled an old belt to make a holster;
- recurred to BLF members as suppliers of materials for the mod;
- had to improvise to get the job done;
*…had fun and learned
This is it! It’s done now
Now, some photos of the flashlight, the wood support and the holster, and also the beam and the glowing parts
Beam Profile!
Unfortunately I wasn’t able to test it outside, so here are some inside beamshots! (WB 5000K)
To make these beamshots I temporarily configured the flashlight on the mode 8 (8 levels) + moonlight, so below you have 9 beamshots showing the progression of luminosity.
The battery used was a not fully charged Sony VTC6 3000mAh, unprotected.
With a luxmeter, just to show the evolution
In the wood support Note the orangish/reddish glow that comes out of the wood support after the light is shut off
Some beamshots comparing the modded Amutorch VG10 to the:
Skilhunt M150 w/ Luxeon V2 5000K (left) and the Lumintop Tool AA V2.0 Panda White w/ Luxeon V2 3000K (right)
Wuben T050R w/ Samsung LH351D 5000K (left) and the Emisar D4 w/ XP-G2 S4-3D ~5000K (right)
The glowing on the light and the holster. Despite dim, if compared to a green one, the tritium vial is quite nice and in pitch black environment helps to find the flashlight, which is the its main purpose
And now, some glamour photos of the set!
Thanks for the all the comments and tips given here, and thanks for the opportunity to participate in the Old Lumens Flashlight Modders & Builders Challenge 2019 !
I also would like thank to CRX, kiriba-ru, led4power and Lexel for providing invaluable pieces for this mod: without their work, this mod wouldn’t be possible as I imagined it, and I wouldn’t have in hands a dreamed flashlight !!!
To the other contestants involved and still on the run, good luck and good work on your builds and mods, and let’s show how BLF works
Peace & Light!
Nice sum up MascaratumB. I’ve enjoyed following your post from start to finish. Its nice to see the other members hear chip in with parts.
Did you get any odd looks when you were taking pictures on what looks like the side walk?
Very nice ” MascaratumB ”
You project and presentation has set the bar for the rest of us to reach
I really enjoyed looking at your pics and reading all the experiences.
Pretty sure you will be hard to beat, Great Job
