Gonna be a wall of light?
Now I’m also curious with the beam of this
Thank you, MRsDNF and CRX.
It should be quite a bit floodier than the SST20 in the MF01S and maybe brighter.
I will for sure compare it to my SST20 4000K MF01S. :sunglasses:
I guess you’re still waiting on parts since you were a bit of a late starter?
Thank you pinkpanda3310 for the reminder.
I just updated my first post. Here is a quick summary of the current status:
1) The LH351D’s in 4000K are about to arrive.
2) I have ordered the 30mm driver and MF01 aux led board from Lexel. I may get it in early February.
3) Some copper rods with 16mm and 20mm driver that I already have will be cut to length and used for the spacer along with a 6mm thick copper plate (on the way).
4) I don’t know where my Sofirn Q8 side switch is currently, maybe it shows up in time. If not I will recover a switch from another flashlight.
5) The hot plate for reflowing will most likely arrive too late so the hot air station will be used once again. Maybe with a new MCPCB and fresh soldering paste it will not be too difficult to melt. Reflowing seven leds at once is already a challenge, just figure with 18 leds…
I expect to start the build in the first week of February. First I will fit the spacer, then reflow the leds and finally solder the PCB, switch, aux leds and driver and assemble everything.
Nice design Skylight,
We are excited to see more pictures.
Thanks, CNCman.
There will be many pictures as the mod proceeds.
UPDATE: All the parts and some modding supplies have arrived now! So let the modding begin!
These are the things I have been waiting for. Note that the hot plate for reflowing has arrived shortly after I posted that I don’t expect it to arrive in time.
Interested/following this build. With the size and ability to soak up heat on this L6, I’m hoping this would be an ultimate turbo run time monster. The MF01S is nice in a small size, but turbo run time is lacking.
Thank you for following, YogibearAl. I assume that the turbo runs longer with the copper spacer I will use but the total runtime will be less than the MF01S.
Here are some more pictures and a complete parts lineup. Only the Sofirn Q8 switch is missing.
Also, the batteries that I will use in this flashlight have arrived, the Golisi S43 with 30A continuous discharge rate.
Oh boy, I wish I was so “clean” preparing to mod It would make my life better
Great that the components arrived! I am really curious to see how this light will shine
Good work
Nice pictures and thorough preparation.
I wish you everything fits as planned, I’m really looking forward to the result.
Neat idea! Looks like it should perform well and make it all worthwhile. Look forward to beam shots…
Thanks, MascaratumB! Almost half the work is needed for the pictures but that’s worth it.
I have started the mod now when others have already finished but I think I will make it in time.
Thanks, man of light! The mod is in progress, more pictures coming soon. :partying_face:
Thanks, DB Custom! Maybe it will inspire others as well because I like the combination of L6 and MF01S.
I have done a few more things in the last few days.
- Soldered double BlueSwordM Gen3 silver plated BeCu springs on the tail switch board
- Changed the black switch cover to a white one
- Reflowed the 18 LH351D’s to the MF01S MCPCB
Some fotos before the reflow with clean board
Applying the solder paste and placing the leds
After the reflow
Some leds are not placed perfectly but they are not too far off. I had to widen the holes a bit to make the legs of the optic fit.
The last picture shows the special tool used for widening the holes on the MCPCB without damaging the led domes .
- Soldered 18AWG wires and double BlueSwordM Gen3 BeCu springs to the driver board
Next thing to be made is the copper spacer.
Look what has arrived on last Friday: my Sofirn SWITCHES:
You don’t see any switches? Well, me neither!
But seriously, I won’t complain at all about getting BLF Q8 drivers instead of switches. That’s a nice surprise and an incredibly good deal because I always have good use for those drivers.
The only problem remaining would be that I need a switch for my build. So I thought I will take the switch out of my Sofirn C8F host and see if I can get the green and red indicator leds to work with Lexel’s driver. It would be awesome to get a red switch when the battery is low.
Looking Good ” Skylight ”
Cannot wait to see more
I like the 18 gauge wire, some of my lights need that too.
Also you have a sweet hotplate too ” UYUE 946-1010 LED Display Preheating Platform ”
Thank you, CNCman.
Yes, the hotplate works well and is definitely needed for soldering a 300g copper spacer.
The date at the top of each post represents the actual day when I have worked on the flashlight. It is not that I have finished it all today.
02/19/2020
- Tested the length of copper needed with a stack of copper coins (2- and 5-Cent coins)
- Cut three 3cm pieces from the 16mm copper rod
