good work…my number one gripe with an edc is the light coming on in my pocket. which is why the only one i have is the jet mini-1.
Will it be possible to add a SMD LED on any part lf the clip (the internal part… The part facing the flashlight body…… Or other location) to show when the bypass option is activated/deactivated??
Why is it that we’d want a bypass option rather than just making the contact/switch design of the clip ultra reliable?
I’m interested. I’d love to test one out.
Interesting I don’t usually use clips except for my EDC pocket knife. Would be interesting to test this out. I think clipping a knife and a flashlight would require more pockets? Or else they’d be scuffed up next to each other needlessly.
I renamed my post in the Commercial section to just ClipSwitch Flashlights. Sorry about the confusion but everyone from both posts will be entered into the giveaways.
Thank you. No problem
I’m in for the GAW, looks usefull to use at work
is there a chance there wil be a 2x AA or AAA clip switch flashlight ?
keen !~
It’s a definite possibility. I’ve not found an easy 2x host to mod yet but there could be one out there. Also, custom flashlights and really any production clip switched flashlight is possible.
That is unless you were to use a pocket organizer such as one from Yellow Birch Outfitters or similar. Then it can be clipped while inside your pocket!
You could modify a Stylus Pro or Stylus Pro USB exactly the same way.
Cool idea, very interesting
You could use some liquid electrical tape on the Stylus Pro tailcap, after sanding the threads down a little to make them looser, and get away with it for a while. Problem is there is no recharge port and taking the tailcap on and off will ruin the tailcap isolation. The Pro USB would work but you’ld have to move the pocket clip up (possibly requiring a pocket clip from a Microstream USB) making the light pretty long for sitting down in a pocket.
That’s a great idea! I like how you can still use the tail switch and have the clip switch. 300lm out of that and it’s something I’d definitely carry around.
Interesting and interested
Thanks Sirstinky! The average Microstream outputs around 50 lumens on low and 250 on high, but the black one I’m giving away just happens to be at 60 and 300.
Interested, thanks
I dont own any streamlight. Are they made in USA or in China?
They’re made in China. My favorite pen lights are their Stylus Pros. They’re cheap and pretty robust for what I use them for.
