M4D M4X deals - Astrolux WP1 and WP2 LEP
Max, any chance for BLF sp36 anduril XPL with 3 batts version?
the code above still works for the other LED
Ha Martin! Used your code on a brass MF01 mini with 4000K SST20's and it came today, 13 days from ordering w/free shipping. It's outstanding!! I have an olive green MF01 mini w/5000K SST20's and these 4K's are way much better - milky white on the white wall while the 5K's match the body color, olive green ().
Popped in a Shockli 5500 26650, then in Anduril:
  • set the AUX LED to max
  • cal'ed the temp (it was ~10-12C high)
  • cranked up the temp regulation to the max of 70C (40 clicks)
  • set the ramp max to the turbo/max
and now it's all set . Batt voltage so far is dead-on as well.
These 4K SST20's in this light look great to me, as consistent as XPL-HI's and no noticeable tint shift in the spill or corona, and no signs of green.
Very happy with the brass 4K light!!
Now to grab the copper shim for thermal help :wink:
Also noticed the same with the 5000K - I’ll be putting in sw45k.
Bras does ok. Think I heard about the copper shimes - is someone selling them? I don't like the 70C limit. I already modded Anduril to max at 85C - much better for a light like this, just need to find out how easy/hard it is to re-program. I already maxed out at 70C on this mini and can still hold the light in my hand fine, but it gets hot for sure but I've held hotter.
MF01 Mini / MT07- Mod/Upgrade - Copper Heatsink Cover Plate :slight_smile:
The shim only effects max ramp. The 7135 chips overheat the MCU causing it to thermally step down after 20 seconds or so. With the shim, this changes to several minutes like it should be.
Yep, just ordered 2 shims, plus I'll dnld my version of Anduril with the raised thermal limit of 85C, from 70C.
Huh? I assumed you just set the ambient 15°C lower to get 85°.
No - much better when the firmware supports it. Again, compiled/built the latest released Anduril (464) on Atmel Studio 7 (latest), and tweaked the max allowed temp. Dnld'ed and tested a Anduril Q8 build on a Sofirn Q8 - works great!
Not sure bout the version # - now I can't find it in the repository - it's so confusing.... Think it's the latest "sandbox" version, not released.
Think at the time, the other day I pulled 464 dated 2019-12-18, and that's what I built and modified.
thank you all for your patience - china added another week where all people need to stay home to prevent the virus to spread easy
Best stock market tip of the year so far. Thanks!
Stock market tip?
Am I missing something?
Sorry for off-topic. Markets have been expecting coronavirus to have little impact on global economy because everyone would come back to work only a week late. This looks like wishful thinking at this point.
Hello my dear friends!
The Chinese New Year is over and after some delay due to the nCV its time to get back into business!
Here are some new deals for you:
NITECORE® CI7
4x XP-G3 S3 2500LM Memory Function Tactical LED Flashlight 7000mw 940nm Long Range Infrared IR Illuminatorp
p
lease contact me
NITECORE i4000R
XP-L2 V6 4400LM 230M Type-C Rechargeable Tactical LED Flashlight
please contact me
ReyLight Copper Pineapple Mini
Nichia 219B 300lm 4500K R9080 High CRI EDC LED Flashlight AAA/10440 Mini LED Keychain Light
my code: M0857 your price: 35.99 USD
SKILHUNT® M200
XP-L 1100LM High Power Dual Group Mode USB Rechargeable EDC LED Flashlight
ON THE ROAD 311
720lm 11Modes USB Rechargeable EDC Tactical Flashlight with 16340 Battery
my code: M5666 your price: 34.79 USD
MECO Hand Crank Solar Power Energy Rechargeable LED Flashlight For Camping Hiking
my code: M6168 your price: 5.79 USD
Woah, the Nitecore CI7 has a rotatable head to switch between 4 regular led and 4 IR leds? That’s cool! I’ve never seen that before. Just pull the head out, rotate 1/8 turn and drop back down.
I need a video. :smiley:
Today i present you a very nice deal for my Members and Friends:
VAPCELL S4 Plus 3A Battery Charger
M4D M4X price: $31.99 (ends 2020/3/30)
my code: M5094 (use the link above)
Features:
3A each slot ,12A in total.
Charge/Discharge/Capacity test /Repair
Automatically select the optimum charge current.
Easily choose current you want at manual mode.
Wide & High charging current choice: 0.25A /0.5A /1A/1.5A/ 2A/ 2.5A/ 3A for eachslot.
Show charging status in real-time like voltage ,capacity,temperature,time,current.
Enough space for 21700 battery, even button top 21700, PCB 21700 .
Top surface have a button top type feature to make contact in recessed battery
It is compatible with every type of rechargeable battery.
Support 4 slots charging independently without interference.
Automatically activate and repair “0 voltage”lithium battery.
Automatically calculate battery charging time.
Automatically calculate the battery percentage.
Charging protection, over-discharge protection and protection of polar reverse,shortcircuit protection .also, it can detect a broken battery.
Temperature control protection.
Keep your battery safe, most important,your lifesafety.
Intelligent power bank 5V 1A.
Certified by FCC CE ROHS.
more deals…
SPERAS E1
XP-G3 500LM 170M USB Rechargeable IPX8 LED Flashlight Outdoor 18650 Flashlight
ask me for the deal!
2pcs 18650 Basen $12.99
Battery lithium ion battery cvell 3.7V 3100mAh/40A/50A 3200mAh/40A
use my code: MBS181
Any chance of a code for the M200 high cri version?
link?
Cant see it on any sites yet, but:
Has an LH351D in it.
