Bras does ok. Think I heard about the copper shimes - is someone selling them? I don't like the 70C limit. I already modded Anduril to max at 85C - much better for a light like this, just need to find out how easy/hard it is to re-program. I already maxed out at 70C on this mini and can still hold the light in my hand fine, but it gets hot for sure but I've held hotter.
The shim only effects max ramp. The 7135 chips overheat the MCU causing it to thermally step down after 20 seconds or so. With the shim, this changes to several minutes like it should be.
No - much better when the firmware supports it. Again, compiled/built the latest released Anduril (464) on Atmel Studio 7 (latest), and tweaked the max allowed temp. Dnld'ed and tested a Anduril Q8 build on a Sofirn Q8 - works great!
Not sure bout the version # - now I can't find it in the repository - it's so confusing.... Think it's the latest "sandbox" version, not released.
Think at the time, the other day I pulled 464 dated 2019-12-18, and that's what I built and modified.
Sorry for off-topic. Markets have been expecting coronavirus to have little impact on global economy because everyone would come back to work only a week late. This looks like wishful thinking at this point.
Woah, the Nitecore CI7 has a rotatable head to switch between 4 regular led and 4 IR leds? That’s cool! I’ve never seen that before. Just pull the head out, rotate 1/8 turn and drop back down.
Features:
3A each slot ,12A in total.
Charge/Discharge/Capacity test /Repair
Automatically select the optimum charge current.
Easily choose current you want at manual mode.
Wide & High charging current choice: 0.25A /0.5A /1A/1.5A/ 2A/ 2.5A/ 3A for eachslot.
Show charging status in real-time like voltage ,capacity,temperature,time,current.
Enough space for 21700 battery, even button top 21700, PCB 21700 .
Top surface have a button top type feature to make contact in recessed battery
It is compatible with every type of rechargeable battery.
Support 4 slots charging independently without interference.
Automatically activate and repair “0 voltage”lithium battery.
Automatically calculate battery charging time.
Automatically calculate the battery percentage.
Charging protection, over-discharge protection and protection of polar reverse,shortcircuit protection .also, it can detect a broken battery.
Temperature control protection.
Keep your battery safe, most important,your lifesafety.
Intelligent power bank 5V 1A.
Certified by FCC CE ROHS.
