Great idea! I don’t have mine because my nephew wanted it.
So I ordered another and my brother-in-law wanted it. Since they were $8.99, I gave them to them. They wanted my Sofirn Q8 and said “no way, Jose!”.
Received mine today, seems like a very solid well built light to me. Testing out the battery now on my Engineer 500.
Ordered another as a gift. Nice non treated glass,metal reflector, looks like s 20mm mcpcb. The pill looks removable. The head seems glued to the body. Cant tell what LED is in it. Tint isn’t blueish on mine. Beam pattern is a little ringy but not bad at all.
The pill is what holds the driver and the LED board, in this case it screws out from the top under the reflector.
You can see 2 small dimples at the rim of the pill, these are for using clip pliers/needle nose with sharp tips or tweezers if they are large enough.
Most of them will un screw counter-clockwise but some are clockwise threads.
Once removed then you can tackle removing the driver if needed. Also easier to unsolder LED board for replacement or to just reflow the emitter itself.
If it is what we call a brass pill, It’s not really brass but is a heavier blend of metal than the ordinary aluminum.
Yes it’s a good thing, cost more to make them that way and they will generally take more heat.
Brass pill by itself will usually cost 4-6 dollars by itself.
I just ordered one. Seems like an awesome price because you get a 5000 mAh 26650 battery, a charging cord, a nice packaging box to store it in or to give as a gift. PLUS! it will be delivered in two days.
If it turns out to be all that, and a bag of chips, I will buy a couple more.
