Astrolux HL01 Too Throwy Solutions
I’m gonna try both the film first and a Samsung led and reflector mod after they get here :slight_smile: .
  1. [quote=ch1ir] What is this DC fix, and how may I aquire some? [/quote]
There’s more info here. DC Fix
I like the diffuser film better than a “mule” because the mule has a (mostly, except for a small hotspot from the emitter) evenly lit cone of light, while the diffuser provides a hemisphere of light. With a reflector it creates a beam profile that is nicely transitioned.
It depends if you want uniform brightness (like a zoomie in wide mode), or if you want really wide spill for seeing where you’re walking/working/etc and might still want a little bit of hotspot/throw.
As Boaz mentioned above regarding my posts on the subject, I like #7 for my SP40 headlamp.
Someone just asked something similar a while back.
I’d rather stick an aspheric lens in there vs leaving it as a mule. A mule lets light go all over the place to the point where it’s so diffuse that lux is down in the toilet. Think of it as more of a 160° lantern than flashlight/headlight.
At least an aspheric lens would still give a nice even blanket of light, but it wouldn’t be spread almost 160° like a mule would.
If you’d still want light to be a bit more concentrated in the center, then heavily-diffused film would be the best option. I’ve got a WW Xeno E03 with DF on it, and it’s a nice warm blanket of light, too, but you can tell there’s a bit more light in the center that nicely and gradually fades as you go off-axis. That’s my go-to light around the house unless I really truly need firefly mode. (And diffusion film comes in various grades, from lightly to heavily diffused.)
That said, if you can pop out the ring and reflector, and it’s 20mm or so and can fit a 20mm TIR lens depthwise, that would let you select any spread you want, from 5° spot to 120° flood, for less’n a buk a lens.
Ahh good now I have more choices… aspheric lens and “Mule” which is a flashlight without reflector :-). Boy looks like this flashlight will be my main Mod project :D.
Hmmm I was thinking a mule will definitely give spill and cover a broad area. Sorta like those 100 w Cob led’s that take 30-32v. I still want a little hotspot though. Then a choice of lenses looks like another route. Lots to keep me busy now! :slight_smile:
Another vote for trying dc fix. In the meantime to get an idea of how diffuser film might look try Scotch tape with the matte finish (magic tape). I have not used dc fix yet but the scotch tape works pretty well. The scotch tape might reduce the output more though.
I’m gonna experiment with Scotch tonight. Only thing I have in stock that I need now until the DC-fix gets here lol.
Which dc fix did you buy and from who? I’m trying to get an idea of what I need, thanks
Following is more useful when combined with reading.
I got it from fellow member, Boaz.
More info…
here2
Here
Thanks, I’m at work and I will do “the reading up on” when I’m off.
Bug Boaz for a sample-pack. :laughing:
Forgot the #s, but regular (1?) is a coarse pattern, good if you want to blur the hotspot a bit but not completely trash its throw. I use that on a 2×D Luxpro to kill off the evil pissy beam from the G3, yet still let it “reach” a bit.
The other one (4? 7? whatever) is a finer grain, really diffuse, which is what I use on my E03. That should be the one that it sounds like you’d want. Nice and diffuse, but still a bit brighter in the center and fading as you go off-axis.
But still investigate and play with aspherics and TIRs. You might then hit on the Perfect Beam™ even if only at random.
:laughing:
If you have some wax paper in the house, try that as well.
Just mist the glass and apply the wax paper, trim with razor blade.
If you take the lens out just lay it over the paper and trim, then apply mist etc.
Kills the throw, milks up the tint and it’s dirt cheap, what’s not to love? :slight_smile:
Later,
Keith
Yeah I just asked for samples in my order :-). This way I can choose which films I might want to use for my other lights depending on situation. Sorta like getting dressed for the day.
Hey cool I’ll try the wax paper too! Maybe poke a few holes. Hmmm maybe some shaded colors!
i replaced mine with TIR and im loving the smooth flood.
i used TIR 19mm diameter (same as convoy S2+ TIR) and sand the base about 4mm to match the reflector height.
the oring fit the TIR nicely then screw back without lens or you can fit in lense but need further sanding to match the height with lense.
Be careful not to supper tight screw bezel else u will damaged the AUX LED. just enought tight to water seal
TIR sand the bottom
kazzaaamm :slight_smile:
5 minutes job
Martin reported a big loss in lumens, what do you feel now it has the S2 TIR? Thanks for pic/description!
Did you sand it at low rpm’s? I think sanding at higher speeds might melt the plastic somewhat.
i dont have lumens measurement but im very sure the loss is negligible to your eyes.
yeah i sand low speed.
im very happy with the smooth flood and its more pleasing for close up work.
