Astrolux HL01 Too Throwy Solutions
:laughing:
If you have some wax paper in the house, try that as well.
Just mist the glass and apply the wax paper, trim with razor blade.
If you take the lens out just lay it over the paper and trim, then apply mist etc.
Kills the throw, milks up the tint and it’s dirt cheap, what’s not to love? :slight_smile:
Later,
Keith
Yeah I just asked for samples in my order :-). This way I can choose which films I might want to use for my other lights depending on situation. Sorta like getting dressed for the day.
Hey cool I’ll try the wax paper too! Maybe poke a few holes. Hmmm maybe some shaded colors!
i replaced mine with TIR and im loving the smooth flood.
i used TIR 19mm diameter (same as convoy S2+ TIR) and sand the base about 4mm to match the reflector height.
the oring fit the TIR nicely then screw back without lens or you can fit in lense but need further sanding to match the height with lense.
Be careful not to supper tight screw bezel else u will damaged the AUX LED. just enought tight to water seal
TIR sand the bottom
kazzaaamm :slight_smile:
5 minutes job
Martin reported a big loss in lumens, what do you feel now it has the S2 TIR? Thanks for pic/description!
Did you sand it at low rpm’s? I think sanding at higher speeds might melt the plastic somewhat.
i dont have lumens measurement but im very sure the loss is negligible to your eyes.
yeah i sand low speed.
im very happy with the smooth flood and its more pleasing for close up work.
Nice! gonna add “Sanding” to my ToDoList. Oh I got some Metal Polish and a Dremel too. I once polished the yellow out of an old car headlight assembly. Works quite well too. :slight_smile:
I did it once. Cheap TIR from BG and Ali caused nearly 30% loss, while Carclo just 7%. Didn’t know This seller then.
I did it once too… :smiley:
I tried scotch tape and it smooth out the hot spot and spill area but still throwy compare to TIR.
Yajiamei optic is much better quality than convoy TIR . Clemence have proven with Armytek headlamps.
Likely this one will fit without any modification. The total height of reflector + lens is about the same as this TIR. Just be mindful im using SST20 LED
Link
Hey thanks for the Ali TIR links. Unfortunately they sell in batch of 20 which is quite a lot. I only need at most maybe 5 lol.
Hey nice I saw the Ali link for TIR but they sell batches of 20 only. I just need 5 at the most lol.
Wait… I just had an idea. How about very light hand sanding on a spare lens! That should give a diffused look which is what I want. :student:
If you're not wanting to kill too much throw I have a lighter frosted film that was listed as #2C. I may change the number to #3 since I no longer carry the really heavy/thick material that I was calling #3 . Either way the #2,2B,2C and #7 are some of the nicer frosted diffuser films I carry . I don't think I sent lightbringer any of the #2C but it's great stuff .Instead of throwing out so many samples with orders I am going to make up 2 or 3 assorted packs for people who want to try a little bit of everything .
Hey that sounds great. Variety is good in the beginning. You never know when your taste for color and tints change. :slight_smile:
Got DC fix from Boaz! I put number 7 in my Ultrafire z1, it’s amazing how it works so well.
How do I remove the bezel to the HL01?
Thank for the help from everyone!
Welcome to the better beam club.
Maybe this will help: DC-Fix Diffusion Film Sale - #362 by phouton
Now you need to try the minus green filters and some of the better diffusion film combo .. kinda makes all those ho-hum lights suddenly POP !!!
I just got my DC-fix and what a great pkg!. Thanks Boaz for all the free samples! I need to buy more flashlights now :money_mouth_face:. I did a quick test holding some in front of the HL01 and now I have the spill I need. :sunglasses: Gonna mount film this weekend and post some shots up. :slight_smile:
