Philosophy broadly means thinking about things. Science/math etc are simply subsets of philosophy in that they deal with a narrower set of “things”. Math deals with logic that can be expressed by a certain language. Physics deals with virtually everything in the universe. Chemistry and everything else is stamp collecting. But seriously, chemistry is a more qualitative offshoot of quantum physics because the calculations get too complicated. Biology is sort of a subset of specific kinds of chemistry. And so on… plus lots of links between the different domains. But all relate to thinking about and understanding their domains. So, while I get that philosophy can have some mumbo-jumbo, the common derision towards it is largely undeserved.
As for why to expect the future to be like the past, it’s an interesting question. First I assume you mean the future vs past functional behavior of the universe. The short answer is we don’t know for certain, but we do with a high probability and confidence. The fact is everyone including you makes this assumption on a daily and ongoing basis, consciously or not. Science formalizes it a bit. Some points on why it’s a reasonable assumption:
consistent observations in support: we keep observing the same patterns of behavior
lack of observations to the contrary: we have never managed to find the behaviors changing in place or time without some other cause
utility: if the future is like the past and we learn past patterns, we have some useful knowledge going into the future, otherwise we remain ignorant. If the future is unlike the past, we wasted our time, but also, we have bigger problems!
currently the most sensible position to hold: why should we expect the future to be different from the past?
So, the answer is because it works and has demonstrated benefits.
It’s common for people to be uncomfortable with uncertainty. But accuracy usually requires it. You can have certainty… if you don’t mind being wrong.
We don’t know for certain if the physics of the universe will remain consistent. But it’s also pointless not to assume it.
Your criticism applies to some scientists, maybe, but not to science. The whole idea behind science is to reduce bias as much as possible. All the criticism of science in this thread is criticism of people tainting the scientific method with bias due to various motives other than seeking the truth. The fact that people corrupt science to their own ends doesn’t make the scientific method any less effective at eliminating bias and illuminating reality - if it is not corrupted and is done properly.
The same smear campaigns are often directed at scientists by those who are pushing agendas based on non-scientific methods of defining reality. This has been going on for centuries- so the arrogance can go both ways. In our government in the USA now the government scientists are often forbidden from even using certain words and phrases that come from science in their reports.
As for it being a “monumental flaw” of science that it does not accept something as true unless it can be verified through the scientific method: that is not a flaw, it is the essence of the usefulness and value of science. Sure, things that aren’t capable of being tested through the scientific method can be real, such as your real psychological feeling about a person or object. But can you argue that the gravitational constant or the speed of light is real, or that you’ve calculated them accurately, without testing using science? No, you can’t. You’re talking about different types of reality, which require different types of evidence for us to believe in them. When it comes to defining and proving what is real in the natural world and what is not, science has no peer.
Nothing about this Earth is constant or consistent or repeating unless you are talking about very short time frames. The scientific consensus is that all of the continents on this Earth where at one time one massive land mass. Nobody believes we’re going back to that point. There seems to be consensus that at various times magnetic North and South Poles have flipped. I don’t believe there is any consensus as to how often that has happened or what has caused it . All of that molten material in the center is a likely cause. So the bottom line is that Earth and everything on it is constantly evolving. Asteroids, volcanoes, plus many other “natural” phenomena can not be predicted. So different people are thinking about different time frames when talking about repeatability and what the “future” will look like. And these variables cannot fully be accounted for in the earth’s past.
That is a pile of assertions contradicted by the very existence of entire disciplines.
Astrophysics deals with very large time frames, asteroids, planet formation etc.
Geology and the relatively recent breakthrough of tectonic plate theory explain and predict continental drift, volcanoes, earthquakes and many other phenomena.
Seems like you’re arguing that, if a scientific theory can’t predict all change forever, it has no value. That denies several realities, not the least of which are: 1) that many scientific theories incorporate predictions of change in one or more variables over time; and 2) a theory can be useful even if it can’t be 100% accurate and can’t predict everything.
Please be aware that nobody claims to predict the weather years in advance. Climate and weather are related but distinct concepts.
Consider a grossly simplified analogy: if you have a good random number generator, you can not predict what any single output may be, although you can learn trends like the maximum and minimum range it operates within, and you can observe the average result.
If you modify the code by adding what for the sake of similar terms I will call a “forcing factor,” which multiplies the random number by a non-random number, the effect is predictable even though specific numbers still are not. The minimum, maximum, and average will all be affected proportionate to that forcing factor.
When talking about climate research, the forcing factor is not easy to determine, but it does relate to several fairly well known physical effects that we can attempt to quantify. There is uncertainty, so the research concludes there is range of possible results, not a single fixed prediction, but the overall range indicates positive, non-zero forcing.
The end of life as we know it is actually is not a predicted effect for what you’re getting at, although politicians often make such a claim, and journalists sometimes do.
The distinction between what scientists predict and what others say is a source of sometimes serious trouble for researchers. A meteorologist in my area recently had his job threatened, partially as a result. One of his colleagues was previously kicked off a state government advisory board after proceeding to publish research showing one of the board’s talking points was over-stated. Note, in both these cases, the researchers concurred with others about the reality of the effect they were discussing, but the magnitude was different between their data showed and what others expected.
I think it would be more accurate to say it is not a flaw because accepting something true or not is not what science does.
Science is the method. Accepting something as true or not is an individual decision that can be guided by science as long as a way of applying science to the question can be identified.
I was basically making that point - except that I would say hypothesis testing is what the method does, and hypothesis testing does test whether a hypothesis is true or not true under the test conditions.
The old “weatherman can’t predict …. how can climate scientists” question is pretty well answered in a number of sites. That search will find quite a few of them.
Strictly speaking, hypothesis testing does not accept claims as true. It either rejects claims or fails to reject them.
That’s “true” in the mathematical sense, which means true for all possible cases. The results of hypothesis tests and the scientific method will often be true for all practical intents and purposes in that the result is known with a high degree of confidence. But there is an important logical/philosophical distinction.
“Philosophy” being used as a not-quite-insult toward modern science is the perfect demonstration of so many people not understanding what epistemology is in a general sense, how important to our understanding of the world it is, and how it interacts (and is intertwined) with linguistics, sociology and psychology.
40 years ago scientists/experts were predicting large increases in human population. That turned out to be true. At that time they were predicted that we would run out of crude oil in about 20 or so years, as in 20 years ago. That turned out to be a very bad prediction. If that prediction had not been so wrong it’s possible that other scientists would have been predicting global warming long before they started to. It was clear to me that massive population growth would cause pollution of streams, rivers oceans and certainly air, and also consume large quantities of many of the Earth’s natural resources. I value science/scientists and believe that most scientists are working in good faith. I’m simply pointing out that some variables are always going to be wrong in predicting the future. Always. I’m not suggesting that they should stop trying because of that.
And? For some reason this is a surprise to those who don’t understand that knowledge is incremental and asymptotic. Or those who expect certainty.
More importantly, we need to be clear on what is meant by wrong, and have a sense of proportionality. Wrong in what way and by how much? A great saying is “”All models are wrong, but some are useful.“:https://en.wikipedia.org/wiki/All_models_are_wrong”
The only absolutely correct model for a dataset is the dataset itself, i.e. a model that has as many variables as data points in the dataset. But at that point why bother modeling? Trying to describe a tendency with fewer variables means some approximations are made. That’s not an “error”, it’s a practical strategy for making a problem tractable. It makes it possible to get a useful answer instead of no answer or a simple but useless answer. Incrementally improving a model could be seen as admitting that all previous models were “wrong”, but that’s misleading.
PV=nRT is wrong. F=ma is wrong. It does not detract from their usefulness.
“”I wasn’t trying to predict the future”:To prevent the future Bradbury told John Miller in a 2003 Wall Street Journal interview, “I was trying to prevent it.”
I think “if this goes on” was the key consideration that first Earth Day of 1970. A question basic to most science fiction.
And now? ” Almost half the songbirds”:| Nature of Things are gone. Who knew?
Clickbait/misleading title. Unfortunately no links to actual papers/models.
For the most part, the models “failed” for the best possible reason: people reacted and changed behavior: increasing agricultural output (GMOs!), banning certain pesticides and chemicals, regulating pollution, developing new techniques for exploiting resources previously not feasible, etc.
It would be best to see the actual papers, which almost surely have phrasing like “if the present rate of X continues… then Y”. Since the condition fortunately became false, it’s not that the predictions were wrong, they served their purpose!
The other example is just terrible:
That is not a prediction from science, but a personal opinion/bet!
This former science journalist does a good job of presenting what the science (papers) actually says, and clearing up misleading cr@p from clickbait articles, politicians, and “personalities” on all sides of debates:
