I ended up just super gluing the factory orange o-ring. Now it doesn’t move
One of my 3 reports 0.2V low.
ToyKeeper said I could tweak the code to correct this, but I’m passing. It was a gift for one of my sons, and I was delivering it in person a couple days after it arrived. I’m fine flashing the LT1 with compiled code, but I’m not ready to change code and recompile, then flash.
Yes thanks for the help.
Am I correct that you can charge it with up to 12V?
Yes.
Does anyone know if it is possible to change the speed of the flickering light in candle mode? I remember some one being able to do it.
I have not heard of this until this post.
It’s not easy to tell from the UI chart for Anduril, but try this: In Candle mode, Hold the button down. To slow it, Click, then Hold.
you can make the intensity higher or lower, but not change the speed of the flicker to faster or slower. Its one or the other. Faster/slower applies to the party strobe and tactical strobe.
In candle mode you can only adjust the brightness (same as in bike flasher), the faster/slower is for the 2 strobe modes.
My LT1 is on its way for review, it’ll be interesting to see if Muggle mode works on this Lantern.
I guess that’s just the tolerance on the measurement? .1 or so volts out of 4 is 2.5%, which isn’t so bad I suppose.
I wrote a mod to Anduril to calibrate the voltage readings btw... Tested it, working so far on a Sofirn SP36. Works just like thermal cal - while you are blinking out the voltage, click 4 times, there's one config setting, click 1 to 10 where each click is 0.05V. So clicking 5 times sets the voltage fudge factor to 5, 5 is 0.25V, clicking 10 times sets the voltage fudge factor to 0.50V, etc. It saves the setting, just like temperature calibration, to eeprom.
sounds interesting!
Is it too late to get in on the group buy?
Hopefully I can get a coloured version.
The group buy is over but you can buy the LT on Sofirn’s website or AliExpress for pretty much the same price. Sometimes you can even find it at a lower price depending on sales, etc.
My Missing LT1
Just received this by private massege from Sofirn along with my reply back;
“Sofirn 3:13 am
Hi do you still need assistance?
You 0 sec ago
Well, I still have not received my lattern and have waited a few hours as you suggested almost two weeks ago.
YES I need assistance!”
Doesn’t look very promising does it?
My LT1 didn’t show up at the end of January as originally projected, so I contacted the seller, Sofirm, through contact-the-seller the link on Amazon.
They responded and requested I wait 10 more days, which I did. Still no lantern.
I contacted them again.
Someone, named Zoe, got back to me and sent me an Amazon discount code for 99% off, she said should was unable to create one for 100%. I used the code to order again and the lantern showed up right away.
So, not a great initial experience, but in the end things were made right and I’m reasonably happy.
Me too, I’m just waiting for the 10 days to be up.
My Missing LT1
I’m not happy. I’ve waited very patiently. I still have no light.
My Missing LT1
Just sent Sofirn this message through Amazon:
Message sent 18 Feb, 2020
If the seller does not resolve your issue within 48 hours of the first message, you can revisit this page to check if you are eligible to request an A-to-z Guarantee refund.
“I have waited and waited and waited for my light.
Please send it to me.”
