One can dream, Really combination of battery and flashlight technology.
Increased battery life, much faster charging without shortening life of battery (some graphene batteries look promissing). Full charge in 10 minutes or less (4000mAh).
LCD screen showing voltage/current, Wifi smart video enabled flashlights with TF card slot as backup (catch the action). Also for tracking battery/flashlight performance data. GPS. Full data acquisition with mobile phone sync.
Matrix LED/laser allows user selectable flood/throw using redirectable LED and tiny mirror reflectors. No more loss of lumens with push/pull style lenses.
Quiet - liquid/peltier cooling - for fanless heat dissipation active cooling - longer turbo run times.
I hope that the next continuous short and long term steps in flashlight development are enhanced battery technology, enhanced emitter technology, etc, all combining to cause continued significant increase in performance/size ratio.
It’s already getting to the point people won’t know what a wall-switch is for their room-lights, now they’ll be able to use an app to do that for their flashlights??
In the War With The Machines, I’ll bet The Machines won’t even have to fire a shot, because the Eloi will be totally indolent and dependent on apps to do everything.
1) USB-C socket. I know it’s more expensive than micro-USB. But I am very willing to pay the extra $0.50
2) Flashable firmware. This would allow the user to keep the light updated with better firmware without changing the hardware. Similar to flashing custom ROMs on an Android phone.
3) Configurable firmware via a computer. Kind of extension of item #2. If the firmware is user-flashable, why not make it configurable? Either via a config file or a more advanced UI with checkbox.
Another idea: Add more physical buttons for non-expert users:
An On-Off switch, which has ONLY the function ON or OFF. Ideally designed in such a way which prevent accidental turning on. The light is turned on at the last used mode.
An Up-Down switch: for scrolling through various modes. Designed to change lighting mode only when the user needs.
Some flashlights do have a dual switch design. Take the TN12 for example. Tail button for on/off and the side button for changing modes. Another flashlight that may appeal to you is the Nitecore MT10C.
Custom firmware PC program that has a GUI for those of us that need step by step. And a connection to the flashlight that is standardized and where you don't have to be a contortionist.
Amen to that! Love to have it run in a smartphone/tablet app.
Doubt this will ever happen but until LED tints in flashlights all become adjustable like Philips Hue bulbs, wish manufacturers would socket rather than solder the stars for easy swapping. 3V and 6V emitters could have different sized sockets to prevent muggles like me from blowing it.
Would like to see more modular design in other areas as well. Drop-in optics to replace reflectors, and a range of diffusing lenses to fit inside any bezel.
And of course, as an avid cyclist, would appreciate bicycle friendly accessories such as handlebar mounts available for every diameter of flashlight body (ones I cobbled together myself probably weigh as much as the whole flashlight, D’oh!) Slide-on aluminum reflectorized hoods that fit around the bezel another wish of mine, am sure the manufacturers could easily come up with sturdier and more attractive ones than the crap I devised. And yeah, I know some flashlight manufacturers already have self-contained bike friendly options but none have all that much battery capacity and adding external USB power banks kinda defeats their original intent.
