burn in tests for fresh led installs
hi guys
ive just changed the drier and led from my black convoy c8+ sst40
to the sand coloured host convoy c8+
after soldering and putting back together , it works. soldering in bad light isnt great but doable, got to test my soldering skills again after 20 years of not soldering everyday
it works, like it should
but what kind of test do you guys to for a burn in. i know the old convoy worked a treat.
the new host sand colour worked, but what kind of test do you do to make sure every thing is working as it should, after you have done something
thanks guys and its almost weekend
chris
For me when I complete a new mod, I make sure turbo works. Turbo tests connections as well as LED thermal management. Bad connections will cause flickering and bad thermal management will fry LEDs. Run it in turbo and make sure the flashlight functions correctly.
tested my newly transplanted sst40 board and driver to my new convoy sand c8
works perfect, soldering was pretty simple in the end
now the black convoy c8 is getting painted black and gold!
