Nice pictures and thorough preparation.
I wish you everything fits as planned, I’m really looking forward to the result.
Neat idea! Looks like it should perform well and make it all worthwhile. Look forward to beam shots…
Thanks, MascaratumB! Almost half the work is needed for the pictures but that’s worth it.
I have started the mod now when others have already finished but I think I will make it in time.
Thanks, man of light! The mod is in progress, more pictures coming soon. :partying_face:
Thanks, DB Custom! Maybe it will inspire others as well because I like the combination of L6 and MF01S.
I have done a few more things in the last few days.
- Soldered double BlueSwordM Gen3 silver plated BeCu springs on the tail switch board
- Changed the black switch cover to a white one
- Reflowed the 18 LH351D’s to the MF01S MCPCB
Some fotos before the reflow with clean board
Applying the solder paste and placing the leds
After the reflow
Some leds are not placed perfectly but they are not too far off. I had to widen the holes a bit to make the legs of the optic fit.
The last picture shows the special tool used for widening the holes on the MCPCB without damaging the led domes .
- Soldered 18AWG wires and double BlueSwordM Gen3 BeCu springs to the driver board
Next thing to be made is the copper spacer.
Look what has arrived on last Friday: my Sofirn SWITCHES:
You don’t see any switches? Well, me neither!
But seriously, I won’t complain at all about getting BLF Q8 drivers instead of switches. That’s a nice surprise and an incredibly good deal because I always have good use for those drivers.
The only problem remaining would be that I need a switch for my build. So I thought I will take the switch out of my Sofirn C8F host and see if I can get the green and red indicator leds to work with Lexel’s driver. It would be awesome to get a red switch when the battery is low.
Looking Good ” Skylight ”
Cannot wait to see more
I like the 18 gauge wire, some of my lights need that too.
Also you have a sweet hotplate too ” UYUE 946-1010 LED Display Preheating Platform ”
Thank you, CNCman.
Yes, the hotplate works well and is definitely needed for soldering a 300g copper spacer.
The date at the top of each post represents the actual day when I have worked on the flashlight. It is not that I have finished it all today.
02/19/2020
- Tested the length of copper needed with a stack of copper coins (2- and 5-Cent coins)
- Cut three 3cm pieces from the 16mm copper rod
02/21/2020
- Soldered the three 3cm pieces of the 16mm copper rod to the 6mm thick copper plate. I had to file them a bit to make an even surface for soldering.
02/22/2020
- I prepared some thick copper wires to fill up the empty space around the copper spacer inside the flashlight.
- Removed the black ring in the switch cavity and fitted the switch inside with a little filing.
02/23/2020
- Removed the anodisation from the parts inside the flashlight that will be in contact with the copper spacer. This may improve the thermal contact.
- Also, I drilled a hole in the copper plate where the wires will pass through. The ‘legs’ of the copper spacer needed some filing to maximise the contact surface with the flashlight body. With my hand saw they got a bit different lengths and are slightly crooked.
- Soldered some 30 AWG wires to the switch and prepared 28 AWG wires for the aux leds.
- The silicone switch cover needed to be shortened a bit, otherwise the switch wouldn’t have worked.
02/23/2020
- Soldered all the wires and assembled the head with the switch, copper spacer and thermal paste + glue
02/24/2020
- The thermal glue had time to dry overnight with the flashlight closed and thin foil to protect the MCPCB from being glued as well.
- I tested the aux leds with the multimeter. Looking nice.
- I put the MCPCB in place with some good 10 W/mK thermal paste underneath and connected the wires for it and the aux led board.
At the first attempt the aux leds did not work, only the green lighted switch.
02/25/2020
The next day I send Lexel a PM and he told me to connect the aux led board directly to the battery voltage. I did that and the aux leds worked. They are not MCU-controlled though and are always on unless the tail switch is turned off. The green switch leds are controlled and have the three options of Anduril and can also be turned off. The red switch leds did not work together with the green switch leds so I unsoldered and isolated that cable.
The pictures of the aux leds are located in the next post’s picture gallery as I took the photos later.
With the aux leds now working I would like to declare the Matainvoy ML18S FINISHED ON 02/25/2020.
I added some GITD tape underneath the optic and took lots of fotos. Here is a little picture gallery to show you those beautiful aux leds.
What a light!!!
That must be awesome in person/hand!!!
Great work! I liked how you used the coins to have a good measure of the height needes for the copper rods
Here is a comparison of the Matainvoy ML18S, the Astrolux MF01S and the Convoy L6.
Some whitewall beamshots
Matainvoy ML18S
Astrolux MF01S, Matainvoy ML18S, Convoy L6
And here are the outdoor beamshots. Whitebalance is 4500K, settings 3.2s F7.1 ISO400. The tree in the back is 150m away.
Control
Matainvoy ML18S, high and turbo
Astrolux MF01S
Convoy L6
My modded flashlight that I called Matainvoy ML18S has a new home as well, a big Maxtorch flashlight bag. It is the only bag that I ever managed to fit a L6 inside and it is definitely better than the generic white box.
