Lume1-FW3X: Constant Current Buck-Boost & FET Driver with Anduril1/2 + RGB Aux
Any estimate on how long until this becomes available?
This is look'n real good! Sorry if I missed this, but does it fully support smooth ramping? We usually use a 150 level table. If I understand this, the first 3 amps is regulated, then after that the FET kicks in. This is similar to how we treat a bank of 7135's. The linear regulated driver in the new Noctigon K1 works similar, from what I understand. Up til now, I don't think TK released any of the 1634 Anduril config files. All I know of is 2 Anduril 1634 lights - the D4SV2 and the K1.
Since it's a OSHPark design, I'm hoping we can build up our own, but that depends maybe on how small you are going with parts. Think there are some 0402's there. Not sure what the FW3A driver size is, but scaling up the size should be easy - just keep the parts as-is and expand the outer space - we've done this before.
So are you planning on developing the hwdef and cfg files for Anduril?
Thanks everyone for the feedback; I appreciate it! There is no specific ultra-low moonlight for this driver at the moment, mostly to keep things simple. I hope the lowest mode setting should be low enough; I'll take more measurements soon. However, it will be easy to add in hardware to enable truly very low modes if desired.
I also understand the concern about the flashlight being silent - I didn't notice any issues on my dev board across different power levels, but need a little more evaluation on the form factor board. Typical sounds come from a PFM or burst frequency, which can cause some sounds if it's below ultrasonic and if the devices (typically inductor) vibrates too much. There are no plans to add integrated charging; it can be done, but I think is beyond the scope for this particular design. I really wanted to keep this as simple as possible and to keep the BOM cost down without sacrificing on the engineering.
Not yet; please follow this thread and I'll update when I can, thank you!
The FW3x has roughly 22mm driver cavity. The smallest parts on this board are the 0402 passives and a SOT723 transistor (along with the other QFN parts). It will be challenging to put together if you don't have some sort of magnification, but should be pretty easy with some experience and hot air. At the moment, the lume1 board for the FW3x has only components on one side (with only the spring being on the other side) - hopefully that helps.
Yes it supports smooth ramping. Also, yes the first 3 amps are regulated; the FET is for unregulated Turbo, and you are correct, similar to 7135s. I have a primitive firmware I wrote to test the hardware and it serves as a simple firmware for now, but I am currently working on the config files for Anduril... hopefully I get it right!
Here's a preview of things to come:
For those concerned, I did put some tape around the flashlight so as not to have it scratched by the clamp. I think this PCB colourway works quite well with the FW3C.
This looks great. I am looking forward to hearing the results of your testing.
If there is enough interest, are there any resources accessible to the community for building a batch of fully assembled boards, even if such a group buy would need to be run by someone else?
Yeah. that PCB color is cool!
Thank you thank you thank you. That’s spot on real for me.
I accidentally stuffed 1 of my FW3A’s drivers. This is exactly the replacement driver it needs. And maybe even the rest of my shelf queen FW lights… Great work loneoceans!
Wow another new driver from loneoceans! This one looks very nice, I like the clean design. I wish it is complete soon! Unfortunately I do not have fw3 light yet, but may have to buy one. Do you think it make sense for non-esiwtch flashlight also?
I am so excited to see this board! It will deal with my biggest wish for the FW3A - replacing the linear topology with a buck boost which will improve the efficiency of the light at the most commonly used power levels!
Secondly, aux LED support is awesome!
Keep up the good work!
definitely interested in a few of these :+1:
Hello all,
Just a quick progress update. I'm happy to say that we have first light with the lume1 driver.
For the flashlight, I used a FW3C bead-blasted host previously purchased from Nealsgadgets. The stock 1+7+FET driver was removed from the flashlight. This is quite easy, but does require desoldering wires from the LED MCPCB first. After that, it's a simple procedure with no glue involved.
The lume1 driver was then dropped into place and installed. As a quick note, the FW3 flashlight has a small screw hole drilled through the MCPCB shelf, which acts as a locating pin for the LED MCPCB to prevent it from rotating when the top cover is screwed on. This screw hole had a few sharp edges on the driver side, which I deburred away.
I think this PCB colourway works quite well with the FW3C. The lume1 driver fits! No issues with the inductor hitting the driver cavity, as designed. Programming was done using a HQ pogopin which I put together myself, and an AVRISP2. You can obviously use whatever programmer you want.
The original emitters were SST-20 4000K 90CRI. They seem to be quite popular, but I never really liked the tint of the SST20s, since they are very green especially at the lower power levels, and never really getting better unless driven at Turbo.
I thought this would be a good opportunity to use some of the fairly rare but extremely nice Nichia 219B 9080 4500K 'rose tint' LEDs I had in the past. These were reflowed onto the original MCPCB. The thermal paste was cleaned up and replaced with Arctic Silver 5. Finally, a TurboGlow glow gasket was added between the optic and the LEDs, just for fun.
Fun Question - if you had to build your own flashlight with this driver, which LED would you choose and why?
But does it work?
I'm happy to say that it does!
Anduril Firmware
With the support from ToyKeeper, I was able to get Anduril working on this flashlight. Fortunately ToyKeeper had already done a massive amount of work with Anduril and it had all sorts of capabilities built in to allow easy support of this driver. Since I work on a Windows machine, I used Atmel Studio for the firmware builds and flashing - I had a few requests about this surprisingly, so I thought it would be better to get something going with Atmel Studio, since most people don't have a unix environment.
There's still a little bit of work left to do for me to evaluate all functionalities of Anduril, but all the basics are working, including:
  • Ramping functionality (in this case, 1024 levels of brightness with 10-bit PWM, similar to Noctigon K1), all regulated with Buck Boost up to 3A
  • Turbo with FET
  • RGB aux LEDs verified working (on my dev board; the FW3x does not have a LED aux board for it, yet!)
  • Standard strobe modes all working (candlelight, bicycle, party, tactical, and thunderstorm)
  • Utility functions working (e.g. voltage reading, lockout modes, aux LED control etc)
  • [Update: External temperature sensor is now working and much more accurate, likely no user calibration required]
There are still some functions on the lume1 board not taken advantage of yet including:
  • 4 solder jumper pads are connected to MCU but no firmware written to take advantage of them yet
Once most of the bugs are sorted out, the firmware will be posted up on TK's repository.
Finally, I took a quick video to illustrate some of the basic functionalities so far:
Please keep in mind that this is a video of preliminary hardware and firmware, and work on it is still in progress.
Regardless, this one is shaping up to be my new go-to flashlight already. It's not as bright as my GXB drivers but I think it's a lot more useful! I'm even thinking of swapping the battery out for a Samsung 35E for longer runtimes since the point of this driver is to be more efficienct. I'm also glad to say that there isn't any issue with noise from the switching regulator at all power levels. And finally, it's not obvious in the video but the Nichia 219B tint is absolutely beautiful, redder than blackbody!
Hopefully this will be a driver which people will find useful. Feedback, comments and suggestions much welcomed.
Thanks for reading.
Excellent! Will the external temp sensing be compatible with the MCPCB’s FROM led4power.com?
Can’t wait for this already!! Most exciting thing since the FW3A in the first place. This is really the only thing the light was badly missing from the beginning (an efficient driver esp for low Vf emitters). I have so many plans for this already!!
It might be a silly thing but the single sided feature with programming pins REALLY satisfies my OCD.
I'm not familiar with how the temperature sensor on the led4power boards are like (looks like just an NTC), so the likely answer is no. There is an external more accurate temperature sensor on the lume1 driver board, which also has a better physical thermal path on the PCB - its should provide a more accurate temperature reading than the internal MCU one. Just need to tweak the firmware to support this since it's simply an ADC read + some math. However, as is, it'll work just as well as existing drivers, which honestly seems good enough. :)
Thanks! I placed all the components on one side to simplify things and it also makes PCB assembly costs cheaper too.
And by the way… The series sense resistor I personally find a bit of a feature to this drivers ideal application, which is allowing full FET power with super low Vf LEDs. I want to run an E21A/E17A quad under a TIR, so this helps me there.
Your an amazing person loneoceans. Nice work. :beer:
great job!
Beautifully done, loneoceans. Very nice. I almost wish the host was transparent so the driver could be seen from the outside.
Well done, maybe I will have aux leds in mine one day after all!
I haven’t bought an FW3A yet, but this driver further increases the temptation to do so. I actually have several 4000K LH351D’s on hand specifically to dedome and put in an FW3A, although I’m not 100% committed to that plan.
I also could go either with 219B’s or perhaps if I were ambitious, disable the FET in the firmware and use E21A’s.
I have a pair of Convoy S2+ lights I’d also like to upgrade from Qlite drivers to a buck driver with Bistro. If Anduril can run on your design, Bistro should be adaptable, as well.
