I bought one from Nealsgadgets last month and he put it in the post the next day, so he might still have some left in stock.
Does anyone know the candella rating for each of the 3 types of emitters?
thanks
Can I ave the code please?
thanks
Have you seen this thread “”BLF D80v2 (WildTrail) now at nealgadgets @ $27.70 (coupon: NDD80V2)“:https://budgetlightforum.com/t/-/58318”.
Ok thank you
Thanks guys
Just curious, where can i find a replacement driver for the Wildtrail D80v2? (I have one with a faulty driver, (only glows & flickers dimly)
I would try to pm tatasal to see if he can set you up with a free one or at the very least a good source.
Actually i managed to fix the driver, found a cold solder junction on the FET.
Code for d80v2 pls
Bit of a necro but thought this might be useful for someone.
Mode groups image courtesy of DB Custom (ignore the arrow). As mentioned already in this thread, default is mode group 12.
Below is info on how to interpret the groups (from TA’s driver thread ).
For reference :
Moon = optional in menu and not shown
ONE7135 = 8
ALL7135s = 14
Turbo = 20Modes approx mA and lumen values for single XP-L LED
1 = 5.5ma = .5lm
3 = 19ma = 4lm
4 = 37mA = 12lm
5 = 66ma = 24lm
6 = 135ma = 60lm
8 (one7135) = 355ma = 150lmAbove this it will depend on how many 7135’s are installed
With 7× 7135
10 = 640mA
12 = 1A = ~335lm
14 (7× 7135) = 2.55A = ~830lmAbove this you are using the FET and it will vary wildly depending on the build.
16 = ALL7135s + 25% FET
18 = ALL7135s + 60% FET
Turbo = 100% FET
Dark brown is nice :+1:
.Is it possible to have a 21700 tube option ?
+1 to this. I don’t mind if the tube is a bit bigger - in fact, it would be preferable.
Just wondered, for the no-ano folks, how did you get on with cleaning up / deburring the battery tube? Or did you just leave it alone?
I polished mine with a rotary tool and some aluminium polish.
I know djozz posted his pic earlier, but this is the best look'n MCPCB I've ever seen. It's worth another take:
If anyone is interested in an inexpensive holster or pouch for the D80v2: https://www.aliexpress.com/item/32490680742.html Works well - about an inch of space at the bottom, but does not detract from usefulness. The elastic keeps the light in place very well.
Congratulations Wildtrail BLF D80… you have been the first BLF light to RUIN, and destroy THREE, i repeat… three ( 3) good 18650 cells, by draining them unexpectedly to 0.002 volts. This is the first BLF light i will throw in the trash. I have never been so disappointed in a custom light as this one… I do not want this to b the last light to fail me at the end of my painful life.
