XHP70.2 P2 4000k Output test by Texas_Ace - it's over 9000!! lumens and still going strong!
90 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 5 hours ago
LichtAn wrote:
Guys what’s the best XHP70.2 emitter for ending up with a nice neutral white without much tint shift after dedoming?
I have yet to find an XHP70.2 that does not have significant tint shift with dedoming.
To end up with a NW tint after the de-dome always ends up with a green tint shift in my experience.
I don’t even mess with de-doming them anymore on my own lights.
LichtAn
Last seen: 3 weeks 3 days ago
OK, this sounds really serious.
Without dedoming the CRI90 emitters seem to be the best choice right? Or do they all have the same shift pretty much?
The_Driver
The_Driver's picture
Last seen: 3 days 21 hours ago
If you want a good tint after de-doming you need to use a very reddish tint (under the BBL) before de-doming.
To reduce the greenish/yellowish corona you need to remove all excess Phosphor after de-doming.
Texas_Ace
Texas_Ace's picture
The only 90CRI XHP70.2’s I have seen were warm white ~3000k. Have you seen cooler 90cri LED’s?
Even the 80cri is 4000k. The 4000k 80cri does minimize the green tint shift my is still gets pretty warm / yellow.
It really depends on if you are sensitive to green / yellow hues. I am very sensitive so I don’t bother with de-doming. Others do not mind at all.
LichtAn
The_Driver wrote:
If want a good tint after de-doming you need to use a very reddish tint (under the BBL) before de-doming.
3A/3D for 5000K according to https://www.cree.com/led-components/media/documents/ds-XHP702.pdf right? Is this completely independent of the CRI value?
Texas_Ace
Texas_Ace's picture
Yeah, it has nothing to do with the CRI.
An A or D tint is best for sure but The ones I have tried still went a bit green, just less then some other tints.
LichtAn
OK thanks. I’ll try to get some of these. 13$ at fasttech…wow
The_Driver
2R and 2U would be even better.
LichtAn
I read somewhere that after slicing the dome, you should remove the rest of the silicone surrounding the die to reduce the tint shift in the corona. Can’t remember where I read that though. Does that make sense?,
Texas_Ace
Texas_Ace's picture
That was KB that said that and it does seem to work for him, although I think he said that is also can tint shift cooler around the edges after doing that just to a much lesser extent?
Overall that is only for the very advanced modders among us.
LichtAn
Because of the precision needed or what do you mean? What if I remove in safe regions and leave a bit of safety margin?
Texas_Ace
Texas_Ace's picture
Yeah, it is very easy to mess it up and kill the LED. Removing only some of the phosphor next to the die I don’t think would be worth it but I have not tried it myself.
You can always try it and see what you think.
LichtAn
Guess I’m in the for the risk, as soon as everthing arrives. At the end of the day, it’s just a dead emitter. Cash
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 hours 9 min ago
Era of dedoming and slicing will be over sooner than you think guys Thumbs Up
LichtAn
So what’s the upcoming Era about? Glueing silicone domes on domeless LEDs? Big Smile
No…
They will simply look like this:
Pavlo
Last seen: 56 min 10 sec ago
Hi ladies/gents,
Looking to update one of my lights with MT-G2 emitters.
Looking to go 3000K or 4000K, 80 CRI min.
Seems like XHP70.2 is the obvious choice. Any recommendations?
Has anybody tried the 80 CRI variants from Kaidomain? Looking to avoid the XP-G3 high CRI puke Green effect.
As for beam quality, will the beam suffer alot going from MT-G2 to XHP70.2?
Thanks
Texas_Ace
Texas_Ace's picture
I tried one of the 80cri 4000k LED’s from kai and it is one of the best tint XHP70.2’s I have tried.
The beam should be tighter then the MT-G2.
Pavlo
Thanks Texas_Ace
Any donut hole? or is the gap in 70.2 close enough to be a non issue?
Texas_Ace
Texas_Ace's picture
That will depend on the reflector / light but as a rule you will just have a slightly dimmer spot in the center, no hole to speak of.
Pavlo
One last question, is the XHP70.2 LED voltage of 6V or 12V dependant on the MCPCB layout?
Texas_Ace
Texas_Ace's picture
Yes, all the LED’s themselves are the same, just the mcpcb that changes.
Pavlo
amazing, thanks so much!
lidas
Last seen: 6 months 3 weeks ago
Hi everyone, I’m new to this forum, I’ve seen this post, I’m looking for a driver project to power this wonderful LED, I have to be able to power it with both 2S and 3S batteries without losing the power of the LED, you know how to help me
Texas_Ace
Texas_Ace's picture
You will need a buck driver to do that. It could be hard to find one as there are not a lot of options.
JasonWW
JasonWW's picture
Last seen: 55 min 42 sec ago
Maybe contact Lexel, he makes Buck drivers, but I dont know if he makes them work with dual input voltages. Maybe.
http://budgetlightforum.com/node/57772
lidas
JasonWW wrote:
Maybe contact Lexel, he makes Buck drivers, but I dont know if he makes them work with dual input voltages. Maybe. http://budgetlightforum.com/node/57772
I need the circuit diagram of the driver because I have to be able to draw the pcb on a specific drawing for the torches that I have created, I don’t like already made pcb
JasonWW
JasonWW's picture
I doubt anyone will share proprietary designs with you. Maybe you can reverse engineer an existing design. Then you’d need to create or adapt your own user interface. Sorry, I can’t help with that.
Texas_Ace
Texas_Ace's picture
All of lexels Buck drivers I have seen are based on the BLF GT buck driver that Del designed. Del posted the schematic somewhere along with the firmware.
Lexel beefs them up with extra components to get around the ~5-8A limit that the base design has according to Del.
