Ignorant here, I have replaced the 219C emitters on my FW3A with 219B ones, no other changes made and I am using a. LG HG2 cell.
Can someone please sum up the issues my setup has and how to fix them?
The 219B config in FSM is 50% FET. I haven’t seen any trouble turboing mine but I’ve never done it for long—and I don’t know if the LEDs get damaged before they start to turn blue.
From where could I download it?
Turbo can’t be disabled via firmware mod?
Mike
Actually, I’m pretty sure TK posted a no-FET version recently.
Edit:
Found it: Index of /torches/fsm
The file is anduril.2019-12-17.fw3a-nofet.hex
One thing I noticed about my FW3 series lights was that the switch wasn’t equal in all of them. My 2 first run FW3As had noticeably stiffer and clickier switches than in the later run models. And one in particular seemed much stiffer. However, even that stiff switch still seemed to require less pressure than all the other switches when those other switches received the o-ring mod and the stiff one had not.
This morning I finally performed the o-ring mod on the stiffest switch.
I’m thinking this might actually be a bit TOO stiff now.
Another installation for my friend. Lexel aux board with direct power from battery, 2 color led, 1mA. Slightly too bright for this setup, but it still cool anyway.
Still pretty bright on moonlight mode
Cool, I like it! :+1:
I traded the fw3d I modded for this fw3a. I didn’t know it could pulse till I tried the different modes. Super happy with it
Quick question.
I just swapped emitters in mine fw3a from lh351d 4000K cri90 to sst-20 3000K 95cri.
It looks 2x dimmer on turbo than before….
Is it normal, that sst-20 produce less lumens?
Mike
SST-20 definitely produces less lumens, but the tint is very nice.
I’d assume that the change from 4000K to 3000K is making most of the visual difference. The Samsung emitters definitely produce more output, but not 2x more.
I was thinking 2x seemed like a lot too. I know there is a big difference between the XP-L and SST emitters.
Thanks, it seems that is normal.
Tint and colour reproduction of sst-20 is really nice. I can live with less lumens
Mike
I agree with you. At first, I was very disappointed in the output, and the heat a little bit, but after getting used to it, I really like it. The tint is great, and honestly, it is not nearly as bright as the XP-L, but still plenty bright.
In one of my FW3As, I had to change the o-ring for the button stiffening mod to a larger diameter one. This was because I got accidental activations. It’s been about a week with the new o-ring and, so far, no accidental activations.
Not my mod. A FW4A mule with 12 Samsung LEDs (LH351D?):
PREORDER!!!!!!!Fw4a MULE 10,000+ lumens!!!!!! (12) Samsung 5000k primaries Green Glow Ring18350 TUBE
Price: USD 189.00
Wow, that is crazy, 10,000 lumens!
I wonder how long you can hold it for on max before your hand melds with the aluminium!
Is there an 18350 cell that can put out that much current?
samsung q30 can put out 20amps
sony vts can put out 30amps
irun samsungs in my fw3 and fw1
ive also got 6 sony vts that are great, but nothing that warrents me putting them in
