Lume1-FW3X: Constant Current Buck-Boost & FET Driver with Anduril1/2 + RGB Aux
I'm not familiar with how the temperature sensor on the led4power boards are like (looks like just an NTC), so the likely answer is no. There is an external more accurate temperature sensor on the lume1 driver board, which also has a better physical thermal path on the PCB - its should provide a more accurate temperature reading than the internal MCU one. Just need to tweak the firmware to support this since it's simply an ADC read + some math. However, as is, it'll work just as well as existing drivers, which honestly seems good enough. :)
Thanks! I placed all the components on one side to simplify things and it also makes PCB assembly costs cheaper too.
And by the way… The series sense resistor I personally find a bit of a feature to this drivers ideal application, which is allowing full FET power with super low Vf LEDs. I want to run an E21A/E17A quad under a TIR, so this helps me there.
Your an amazing person loneoceans. Nice work. :beer:
great job!
Beautifully done, loneoceans. Very nice. I almost wish the host was transparent so the driver could be seen from the outside.
Well done, maybe I will have aux leds in mine one day after all!
I haven’t bought an FW3A yet, but this driver further increases the temptation to do so. I actually have several 4000K LH351D’s on hand specifically to dedome and put in an FW3A, although I’m not 100% committed to that plan.
I also could go either with 219B’s or perhaps if I were ambitious, disable the FET in the firmware and use E21A’s.
I have a pair of Convoy S2+ lights I’d also like to upgrade from Qlite drivers to a buck driver with Bistro. If Anduril can run on your design, Bistro should be adaptable, as well.
This looks super simple to assemble compared to the GXB172. I ended up making a 18650 powered vacuum pen using a cheap motor/pump,silicone vacumn hose and a footswitch from Bangood to deal with the 402’s and temp sensor on it. Have a small syringe and hose dedicated to slurping up excess solder paste as well. Now I use it on everything, fet + drivers are so simple now.
Any chance you will be modifying Narsil to work with this driver? The internal temp sensor is good enough for me. I can see a lot of uses for this driver and modifying Anduril is way beyond me.
This is really exciting. The only drawback with the FW3A and similar flashlights with linear driver is the poor efficiency. With this buck boost constant curent regulated driver that problem will be solved and the FW3A will become a real EDC tool and not just a toy. I wish Lumintop would sell a special batch with your driver.
Please note that so far none of the loneoceans driver was available for sale. Though there’s hope it will change myself I wouldn’t purchase a light before that happens.
Another great peace of work from you loneoceans :+1: . I have one simple question to that driver. Is that will be fully open source or only partial of it? I mean if you will share whole PCB project with source files with full schematic or only gerber files like in anothers of your projects.
Also the best improve over firmware for Anduril is the support of 1024 PWM levels compared to 255 which don’t allow us to use fine steps especially at low modes for LED current regulation in one channel driver.
Excellent work loneoceans. Coming from the GXB172 its hard to believe everything fits on one side of the board with so much space left over.
This driver has so many possibilities beyond the FW3A. Do you think future versions could have pads for Bat+, Bat- and an E-switch on the component side of the board?
Will there be a version of Anduril available that does not use the direct drive fet?
Could you release your preliminary firmware? A few simple modes work best in some applications.
A few people have been asking about using clicky switch firmware with this driver although it would require significant modifications to Bistro and Ramping IOS. Would the input capacitor be able to be used as an off time capacitor?
I have a question: If the IC (I assume it’s a TPS63020) boosts voltage to let’s say 5V, and your battery is 3V, how do you avoid all the current flowing through the p-fet body diode back to the battery?
Presume he used p mosfet as load switch: http://www.farnell.com/datasheets/2049687.pdf
So if it is will be trully open source hardware that will be great. We can improve it or port to another flashlight very easy.
Understand, and thanks for checking. I guess there is no service equivalent to Oshpark for PCB assembly in small quantities?
I’ll be following this thread to see if a perhaps a group buy is ever possible.
I know he’s using a p-fet. I worked on something similar and used a p-fet as well. I ran into the problem that the current of the boosted voltage goes through the body diode back to the cell, rather than through the led. I found a solution to that, but I can’t see how he is doing it on his board.
Hello all, thanks for the kind words everyone!
Regarding the firmware, I’ve got the external temperature sensor to work and it’s a fair bit more accurate out of the box. In fact, I believe I have tested all the features of Anduril as much as possible (though I probably missed out something!), and they all seem to be working.
Answering Tom E with some updates, yes it supports smooth ramping and looks visually identical to the stock driver (see the YouTube video of the preliminary test). I’ve completed the cfg and hwdef files for this driver. There are some very slight optional modifications I made to some fsm-__.c files which I will be documenting in detail, in order to support some extra features such as the external temperature sensor. I stuck with 150 ramp levels, but the control resolution is 10bit instead of 8bit (1023 vs 255 levels), similar to the Noctigon K1. So far, I have configured the ramp tables to have the ramp for the first 3 amps, then the FET kicks in for the double-tap-to-turbo. Keep in mind Anduril isn’t just limited to 255 levels; it’s not difficult to change it to support 1023 levels as long as the hardware is capable. However, increasing the PWM resolution will reduce the PWM frequency, which can cause a little more visible flicker, though at 3.9kHz, I doubt it’ll be a problem for almost all use cases. I’ll put the firmware up on the TK flashlight repo. Just making sure it’s mostly free of bugs right now.
Replying WTF, for driver sales, if there’s a good response, I am actually considering having a small run of assembled boards be made, but I need to make sure it’s got the bugs worked out first. In addition, all files will be published so anyone can make their own as well if they’re interested. I'd also like to hear the reasoning for having additional B+- and ESW pads on the board - what use case are you planning for these? Finally, yes it's very easy to have a version without the FET at all. This can be done simply by either having a run of boards without the FETs installed, and/or flashing the board removing the hwdef for the FET pin. Meanwhile, firmware work is well underway - I actually found a few more small issues and have fixed them!
Next, Schoki knows exactly what’s going on! You’re correct this was something I did miss initially when designing the boards, and didn’t catch it until PCBs were fabricated; this was because in practical use of most designs, the BuckBoost is only operating in buck mode for almost the entirety of the drive range, and when it hits Boost mode, no reverse conduction occurs for my setup. Here's why: LVP cuts out at 2.8V, limiting the lower end of the Vin. For FW3x systems with a 3 LED config at 3A, Vout doesn’t get much more than 3V. Then the key is the bias voltage of the body diode (IIRC around 0.35+V) - together with the low Vfwd of the LEDs used, reverse conduction does not occur.. but just by a whisker. However, you’re absolutely right that a higher Vfwd LED with low Vbatt can start running into reverse conduction of the body diode of the pass fet. This has been fixed in Rev B which is the planned driver for a small mass-order.
As a side note, I’d like to emphasis that having a FET to drive an LED is strictly not a great ‘text-book’ idea, likewise with paralleled LEDs! LEDs are inherently negative temp-co devices meaning that Vfwd of LEDs decreases as junction temperature increases, leading to the LED consuming more and more current until failure. In practice though, with matched LEDs and with system losses, this all works.. but just keep in mind that it isn’t strictly best practice to do so.
Thanks again for your continued interest and support!
I think we should start a sign-up google doc for these. I think the method clemence is using for this Skilhunt GB is a nice way to manage it.
And keep the discussion going folks! I love it :+1:
Thanx for the info! Oh boy, you went way deeper than what I meant, but it's all good. I think I was the one that came up with 150 levels originally for NarsilM (I could be wrong), but I only chose 150 because of the timing. With the levels changing every 16 ms, 150 levels means a full ramp takes 2.4 seconds and I thought that was just right for a light like the Q8, not too quick, not too long.
Just to make it clear, so this driver has buck/boost regulation up to 3 amps, and only ramps up til 3 amps? So it doesn't PWM the FET at all and turbo is assigned to max FET? If so, this is much more smoother than existing Anduril/NarsilM drivers that are FET based.
So if you adapted this design to a much larger Q8 size driver, you could use larger components that could regulate to higher amps? Not sure if you looked at options in detail yet, but might you know how high it can go keeping the cost within reason?
The reason I’d like bat+ and bat neg on the component side of the board is that I’m planning on putting this driver in something other than a FW3A as well as making testing easier. I have some 20+ 2835 and 5730 led battery powered lights that this driver would be perfect for. The vf on the leds is high enough to make them dim before the batteries are discharged and getting rid of the blue and red blinky modes would be nice. The spring side of the driver would be facing the heat sink and spacing it up to clear the wires would push the driver into the battery compartment. I can get by without the pads, should be enough space to solder wires to the input capacitor or scratch some solder mask away in the right places.
