*BLF LT1 Lantern Project) (updated Nov,17,2020)
Thanks to Sofirn for following up some folks in this thread. It’s much appreciated and I hope that any outstanding orders are soon fulfilled.
Yeah, we will ship unfulfilled order as soon as possible. If any of you have concerns about your order, you can contact customer service to know the status of order.
Aside from not having a USB output, it’s a fun, tough, useful lantern.
Does anyone have a link to a solar charger to charging this light, so it can be used indefinitely in case of an emergency?
If i remember this is the one DBSAR used, might be wrong though
Or was it this one
Like i said I have no clue, but most folding out ones will be sufficient.
Both of those actually, but i use the Eceen 10 watt mostly for charging the LT1 during the day. (been using that model & testing it for nearly a month, and its able to charge the LT1 every day to full charge, even on a partly cloudy day. I have 2 Eceen 10 watt units, and other models as well i use & tested.
As long as they are a good quality model that can supply an actual 10 watts of power or higher like the Eceen 10-watt, or any higher wattage models are usually good. (research & reviews usually helps.
This could be useful to those looking at the interface for USB-C. It is about the Pie fixes to the new interface.
Quick Question, I tried searching but didn’t find exactly what I was looking to find. Can you use Samsung 35E NON button top? Do I have to use a button top cell? I’m not trying to add magnets or solder, etc.
It has to be a button top, or a flat top with positive terminal above the wrapping
So a VTC6 would work? I can’t think of anything else that is protruding. Maybe a Sanyo 3500?
I have no clue, I remember there were one or two dollar told that would work, as they have the terminal slightly above the wrapping
Sanyo NCR18650GA’s work. Do not know what other flat top might fit. But do not let a muggle insert a battery upside down, the LT1 Does not have reverse polarity protection.
i need this light
Yes, yes you do
So I know I’m late to the party but are there any deals still available for this light?
AliExpress will probably have some deals, there might be a coupon for sofirnlight.com
Sofirn told me it will be back in stock at the end of April.
