A little trick I use the reverse spring trick on my drop ins.
If you are having problems with the reverse spring not making contact with the small nubs on your batteries take a needle nose pliers and bend the last coil across the middle of the opening like so.
Sorry for the delay, just under 1 hour to low voltage cutoff. Rises to approx 60dC at head. This was tail standing, no airflow at a ~20dC ambient. Details will follow at some point when I have time
Updated original post under 'Battery Life & Heat managment' to show you my recent test. 54min runtime on full with Sanyo 18650, max temp of 62dC (143F).
No problems at all, will prob do another run with a Panasonic cell to see runtime difference. I think outdoors with minimal breeze and with body contact to conduct heat away it would be noticeably cooler. So no problems running on full until low volts and then just stick another cell in :)
This was my first C8 buy (didn't know what that meant a month ago), so looking forward to getting it soon. I'm getting ambitious - also ordered a L2 with the Manafont drop in. "Drop in" - listen to me! What next? Not the soldering iron - I remember the damage I used to do with my brother's one years ago.
Careful, your starting too well! You'll have nothing much better to get lol. Tho there is always turboBBs reviews to read through, just be prepared for a lighter wallet...
Nah, this is cheap - I started with a LD20, then a Caveman, then a SC600W, then a Spark ST6 460NW. Still stuck on single cells, though I expect it won't be long before that changes.
Well, it arrived the other day, with some Intl Outdoor Panasonic 3100mAh cells. Whilst these were charging, I put in a Xtar 1800mAh, that I got with a B01. Looked OK (in the day). Then I noticed a slight flicker. Then a big flicker, then nothing. Mmmm. I remembered a few basics - checked the switch hadn't come loose. It hadn't. Ah well.
When I looked inside I was puzzled to see the spring at the wrong end (hey, come on, I'm still a newbie). I remembered this review, re-read it, and saw E1320's tip about bending the spring to make contact.
By now the new 3100 cells had charged, and I realised that the button on the Xtar cell was much smaller than the one on the Panasonic. Put this in, and no problems.
Checked the dogs in the garden tonight. Bright, isn't it?
Tempted to get this but I'll wait for someone else's view. Throw is fine as is on this kind of light IMO, infact I'd prefer a slightly floodier, smoother beam
I stand to be corrected but I doubt there will be much difference at all. I'd suspect perhaps a tighter hotspot and a little more throw. What are you looking for in your next light?
I recently received my V3 and like it alot. Highest quality I've held in my hands in the C8 configuration. With a Redilast 2900 I get 2.75 at the tail. But I will have to contact Hank about a little problem I'm having with the switch. Whenever the tail cap is removed and replaced, the light only has high mode. The only way to get it to work properly and have 3-modes is to bang the light into my hand, and all works greats until the cap is removed and replaced and that operation must be repeated. I took apart and cleaned all components in the switch, but it didn't make a difference.
I'm sure mine is just a 1 in 100 glitch and I highly recommend this light.
